Results 1 to 15 of 17
Thread: Throttle Body sync.
Hybrid View
    Oct 2008
    San Angelo,Tx.
    Throttle Body sync.
    I have a 2003 1150rt and, I'm going to try to sync. the TB's myself for the first time.Just curious what type of gauges everyone likes to use?
    Thank's,
    Sam
    Vancouver, B.C. Canada
    I've used the Morgan CarbTune and the TwinMax. Both got the job done but this thing beats them both. Very nice tool.
    http://www.advrider.com/forums/showthread.php?t=701625
    There are a couple of YouTube videos out there too.
    Certified Beemerphile TheRoss's Avatar
    Feb 2007
    Texas
    I use and like the TwinMax. I am however a tool junkie and might look into the tool mentioned above.
    If you are real new to wrenching on these bikes, I would suggest buying Jim Von Badens maintenance DVDs. They are detailed and good, and pretty reasonable pricewise.
    Christopher Ross
    Lubbock, Texas
    IBA# 522
    2016 R1200RS, 2012 R1200GSA, 1975 R90/6 (x2)
    Jul 2010
    Tularosa, NM
    Twinmax
    +1 for the Twinmax, BUT -- as with many things, you must follow the directions exactly, make sure that you re-set the sensitivity knob properly, don't bang the needle off the stops, and keep testing the 9V battery before use, as it has to be at least 8.5V to work properly. . .etc., etc. This device has detractors, but at least SOME of these haters aren't following directions, I'm betting.
    Article: Throttle Synching for Dummies over on ADVRider site. . .priceless.
    Opinions differ on the efficacy of doing an "exact" synch while riding the bike at highway speeds -- something that (I believe) is only possible by using the TwinMax, but "some say" that it allows for a more precise adjustment. . .and it IS easy to do.
    MANY great synch tools out there now, so read and research before buying -- they all seem to cost about the same.
    Have fun.
    Walking Eagle
    Utah
    I just got the Harmonizer as mentioned on Advrider above.
    I'll try it. It looks really easy, and can be used while running the bike to get some under load balance, if you are of the opinion that is needed.
    There is the most controversy, I think with dial type gauges. However, I do know some that have used them for many years with good results.
    Motion Pro is the best of the tube types that I have seen.
    dc
    Quote Originally Posted by Walking Eagle View Post
    Have fun.
    Walking Eagle
    Hey WE! Where you been?
    At the end of the day one should used whatever one is comfortable with. I agree that the TwinMax is an effective synching tool when used properly but having used both I have to say the Harmonizer is simply a "better mousetrap". Lighter, less finicky and eliminates most if not all the deficiencies of "other" synchronizers out there.
    Looking at the points one at a time:
    - Eliminates the sensitivity knob. The Harmonizer auto calibrates at startup after it checks the barometric pressure where you are. No guesswork on "zero"
    - No needle to bang off the stops. The display is a smooth (not bouncy like TwinMax) with nicely de-bounced digital quartz display.
    - No need to remove and test the battery. The Harmonizer has a battery voltage indicator on the display. Dead batteries caused by forgetfulness are eliminated with auto shutoff feature.
    - I put a piece of electrical tape at the top of my RT windshield to protect the plastic, hook on the Harmonizer using the handy plastic clip provided (the device is not heavy) and go for a ride after I balance to check it under load. The hoses happen to be exactly the right length to do this. I can watch the road and the display without looking down which is very cool.
    Reading through the features list shows several items not found on any other synch tool product.
    Two other things I really liked:
    - See your exact RPM on the same screen as your balance readout. Very handy!
    - An LED light for better visibility (you can toggle it on and off)
    I'm not associated with the Harmonizer dude in any way, shape or form but I have to say he's done a really nice job on this tool and I have no hesitation in recommending it because I have tested it and used it.
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    +1 on the hamonizer.
    Goodbye Twinmax
    Goodbye mercury stix
    Ufda happens..........
    SportTourer
    Aug 2009
    Northern California
    Cheap way of doing it...works even better!
    I made a simple magnahelic (sp?)gauge using cheap 1/4 inch vinyl tubing, some light weight oil and a yard stick. This is sometimes called a U-gauge. Bend the clear tubing into a U of equal lengths and zip-tie it to the yard stick. Fill the tubing with light weight oil, (colored oil is easier to see), until you have about a foot on each vertical rise of hose. You only need enough oil to see if you're pulling left or pulling right. DON"T use anything water based? If oil gets sucked into your engine, you get smoke. If water gets sucked into your engine, you get a big headache, depending on how much water was sucked in. First ADJUST THE VALVES AND ZERO THE THROTTLE POSITION SENSORS. Then, hang the magnahelic (sp?) gauge above the bike, and attach each end of the hose to the vacuum port on each cylinder (they're on the bottom where the rubber hose attaches). The 2 cylinder vacuums will then be pulling AGAINST each other. This is a really simple tool, but VERY accurate! Adjust the idle air screws in small increments on both sides, until the oil levels balance in the hose, you have a glass smooth idle (look in the mirrors for vibration), and are idling at around 1200 RPM. Next adjust ONLY the Right Side throttle cable so the oil levels balance in the hose at ~3500 RPM. Be careful not to over-heat your Oilhead! It's a tedious process of not-enough...oops, too-far, but when you're done your bike will run soooooo smooth. This simple tool will set you back less than 5 bucks and you'll be able to dial-in your Oilhead perfectly.
    when you say "zero the TPS".... when do you put it back to .370?
    Quote Originally Posted by R1100RS View Post
    read this http://www.ibmwr.org/r-tech/oilheads/zero528.shtml
    explains the entire process. note: only do zero-zero if necessary, and "necessary" means you're bike has a surge that can't be tuned out via the regular valve adjustment & TBS procedure.
    i have never been compelled to do a 0=0, as my bike has never surged.
    SportTourer
    Aug 2009
    Northern California
    My '99 1100RT didn't surge either, but I was amazed how far out the TPS were, even though the bike had just had it's 30K service at a BMW dealer right before I bought it. After I did the 0=0, idle balance, and high RPM balance, I couldn't believe how much better it rode, at all speeds.
    Since BOTH cylinders were now pulling EQUALLY, the low RPM, all torque, parking lot speed, performance was much, much better! Now I can lug it right down to idle and it won't stall. Pulling away from a stop is much smoother now too...hardly any need to slip the clutch any more.
    Quote Originally Posted by SportTour View Post
    that is what is generally called a home made manometer. ATF works better. accurate, cheap and easy, but not very portable. can be made to work on any bike at all.
