I have an oil leak from the joint where the push rod tube which passes through the head enters the rocker area. Oil works its way down the outside of the tube and drips off in the area between the fins on underside of the head (onto top of boot).
Definitely no leaking at cyl to head joint.
Definitely no leaking at head to rocker cover joint.
About enough to saturate a paper napkin shoved into fins in about 200 miles (once a day diaper change for this day ride bike)
Has anybody had any luck sealing this tube to head at the rocker box end from the rocker box without removing the head?
