Results 1 to 10 of 10
Thread: oil pressure
    Grammarian no, Rider yes ISAMEMON's Avatar
    Jun 2006
    Kings Valley Oregon
    oil pressure
    so maybe I am looking in the wrong place ( books and searches)
    for a 85 R80....what should the oil pressure be at idle and at approx 3k
    and at what pressure is the oil light kicking on
    one thread I have read said they run about 60psi, another said over 100
    Ive got a vdo 80 psi gauge and a sender for it thqat I use to check my bmw cars at the block, so thought I would screw it into the sending unit location on the bike and see what IM running. However,it looks like a real tight fit for the bigger sending unit Who knows maybe someday Ill replace the clock aith an oil pressure gauge
    my bike is in witer hibernation now, and I will be doing minor things and tune before spring. I never have checked the oil pressure on this bike, so I thought I would
    I know that ther a lots of variables, beaings, oil pump, miles etc
    Jun 2006
    Kings Valley Oregon
    found the answer myself for a 79 R100.. should be about the same
    this is a fast, informational nice read
    http://www.omnilex.com/public/bmw78/boxloob.pdf
    Quote Originally Posted by Isamemon View Post
    Thanks for posting ! Very good read !
    ________________________________________
    The early bird might get the worm, but the second mouse gets the cheese.
    Jim Carr
    Aug 2011
    Loleta CA
    Oil pressure
    I have an 83 R100RS with a VDO oil pressure gauge. On cold start it will exceed 130 psi. This is with 20/50 and I have just started using 10/40 for the winter with the slightly lower readings.
    After warm up it can read 90 at freeway speeds and drop to 30 at idle. I have not had this set up hot summer weather yet but with the same set up on my old R75/5 years ago it was about the same.
    I have had to replace the sending unit a few times in the past and the one I have in there now is about 6 months old so I believe it is accurate. I suppose the gauge itself may be off some but I cannot tell.
    MOA,NEF,BMREC,VJMC brownie's Avatar
    Oct 2003
    Pensacola, FL
    Talking RS Oil pressure
    Jim.......I run a sender with the idiot light post also....I show 65-70 psi @ 180F (taken at bottom of sump).
    Personal recc: the VDO dual post sender triggers the idiot light @ 17 psi instead of the OEM 4 psi!!!!!!
    Words to Ride by: Patience, Anticipate, Paranoia
    Shep Brown MOA 27510
    "Inga" '04RT, "Fronk" '78 SR500
    Pensacola, Floriduh
    Apr 2006
    PSL, FL
    Quote Originally Posted by Brownie View Post
    Can you elaborate on the DualPost sender? I had not heard of that before.
    Jun 2006
    Kings Valley Oregon
    also do these sender units fit between the engine and the frame. looks tight.
    also , with the link I posted , the bikes are not supposed to hit above 80psi, but from posts here, looks like it can
    do any of the big boy gurus really know and want to share
    Jun 2006
    Kings Valley Oregon
    yep, id rather have a light kick on at 17psi, 4psi is nothing, esp if the bike is supposed to be much higher
    Jim Carr
    Aug 2011
    Loleta CA
    oil pressure
    You need a angel adaptor to fit the sender in. A dual post is a sender that has 1 output for the guage and one for the light then you can have both.
    Jim Carr
    Aug 2011
    Loleta CA
    oil pressure
    [QUOTE=Brownie;730644]Jim.......I run a sender with the idiot light post also....I show 65-70 psi @ 180F (taken at bottom of sump).
    Brownie, Is this at freeway speeds? Also what is your cold start pressure? Oil used? Bike?
    Thanks, Jim.
