Originally Posted by
jconway607
Over many years, I have had to replace the clutch disc, flywheels, pressure plates, etc., on a variety of cars, almost all foreign made. In all that time I have never seen an input shaft with worn splines. Nor a clutch disc with worn splines for that matter. Many of these vehicles had high mileage on them. No one I know who buys a used car with say, 50,000 miles on it, immediately sends it to the shop to have the transmission dropped and the clutch assembly re-lubed. Any car company either suggesting, or requiring that, would be quickly out of business.
Taking these bikes apart, essentially splitting them in the middle on the oildeads-on, is no walk in the park. And often, it seems, the input shaft is worn. Well, there's $1700 for a transmission rebuild. And the worst part is that all you're doing is just re-setting the clock till it goes again. I'm just really curious what it is about these relatively little engines, and even littler clutch assemblies, that makes them so fragile, and such a maintenance problem to own? Like the one guy says, should you expect to split the bike in half every year or so just to make sure your "splines" are not on the verge of failure? This has got to be a moneymaker for the BMW dealerships.
There is no way to know from outside that these things are failing, or have proper lube, etc. As someone looking for a new bike, it's depressing to realize that the first thing I will have to do after driving it home is to disassemble half the machine, with a deep sense of dread that inside that shiny transmission case I will find a worn or shot input shaft. Yes, I know that Japanese bikes have their own problems, but taking them apart to lube/replace transmission shafts on a fairly regular basis doesn't seem to be one of them. Jeeeze, I would think BMW could come up with a solution to this seemingly unending and major problem/headache on their bikes. Apparently I'd be wrong, though.
