Bohan
Those input shafts always wear like that on the Boxers, because of the instability of the clutch hub on the shaft (due to the insufficient engagement). It's not indicative of any particular problem, just that there is a problem that is causing wear.
The same problems cause wear on other designs, but the hubs are stable on the shaft and the wear tends to be even. I've replaced input shafts on just about every BMW model since 1970.
Are you saying that this may not be a case of the often talked about misalignment between cases?
