Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
Is anyone using an android based tablet with an aftermarket nav/mapping program?
I'm considering using one in the top of a see through tank bag setup.
Also considering pairing it up with a SPOT Connect.
1) Leak water into map compartment via zipper
2) cause item to overheat so display goes blank.
Both happened to me on a Garmin GPS. rain almost killed it the first time, really did the job the second. Better to use some kind of mount if possible, and keep out of rain.
