Kind of an odd request, but anyone have VM32s or even 34s that feel like doing me a favor? I know Mikuni sizes their jets based on flow instead of bore and was wondering if anyone could measure the bore of the main and needle jets for me.
The reasoning behind this is that I have some Bing Type 84 32mm round slides that I've been toying with the idea of adapting them to my R90/6. I have quite a few Bing mains, needles, and pilots of various sizes to play with and tune on my own, but figured I'd at least use Rocky Point's Mikuni jetting as an initial baseline. According to the Mikuni jetting chart the VM32s use a 200 size main jet, a P2 needle jet, and a 35 pilot
I don't have any problem with the type 64 cvs that are on it and if I can't get the jetting right on the 84s I'll continue going stock (all 3 of the 84s I have on my shelf cost less than one mikuni, and they don't cost anything to keep on the shelf), but I'll be lightening the flywheel, maybe dual plugging the heads, and switching to high-compression pistons this winter and have been thinking of experimenting with velocity stacks and slide carbs as I've heard some good things about the Mikunis with this setup.
Any help would be appreciated. If I decide to go this route after I get all the other work done I'll be sure to post back with my findings
EDIT: just found a chart for the needle jet which indicates P2 is a 2.66, still could use measurements for the main
