wecm31
Luddite Looney
The Bike
1985 R80RT, I have had it ten years and ridden 75K km (~ 50K mi). PO was a local Airhead of some reknown. I have always used Amsoil 20W50 full syn, I believe the PO used that as well as Golden Spectro semi syn. Oil changed by me at the end of every season. Total mileage on the bike is now 140k km (~85 K mi).
Plan A
I finally got a proper compression check when I took the bike off the road (carbs off, thanks Kurt!). 125 psi right, 130 psi left. Not critically low, but not ideal. This is my only bike and I plan to ride it far and wide in coming years, so I decided to pull the heads and maybe see about redoing the top end.
The timely visit of my Ontario Airharshal David Home accelerated the schedule a bit, and parts began to fly off the bike last week. Upon pulling the right side head, the exhaust valve revealed some nasty chips missing. Wasn't leaking around the seat, at least when we poured some gas on top of the back side of the valve and held the head up, none leaked through. Still, that sealed the deal on replacing all four valves and having the heads serviced.
Plan A
