Luftman said:So, am I to assume that all oilheads could be afflicted with this condition? Or is there some correlation to production date/model year (besides just RTs) that anyone seems to have noticed? Is a first year single spark oilhead as likely to hunt as a 2003?
Thanks.
dano said:My RT is an '03. I bought it brand-new.
It surges in 1st, 2nd, 3rd, and 4th gear......at rpm's from about 1,000 - 3,500 or so.
Once I get to 4K rpm, it starts behaving itself
MarkF said:I don't mean to be a wiseass here. But why are you riding an oilhead at less than 4,000 RPM? A great mechanic gave me a bit of advise years ago about my new then Guzzi. "It ain't meant to be ridden that way." Same applies here.
Yep, I'm the CEO! Sent here to hoodwink you'all into buying a pre '04 oilhead.dano said:You don't happen to work for BMW do you?
Works for me. I love my 2000 oilhead. Your results may varydano said:So.....that's your answer to surging.....keep it above 4000 rpm?
Whatever. I'm gonna ride tomorrow. You can tap keys and put down BMW, myself and whoever else you wish. I know I'll be having fun. I suspect you will too!dano said:If you don't work for BMW.....you should. You'd be a great asset to them, but not so much for the consumer.
lorazepam said:If you want to believe the *emissions* standards are the reason for the dual plugging, that is fine, same with the F bikes. it *is* the reason for thed dual plugs and the emissions story is just to keep from retro fitting all the surging models. Just my .02
Ken K said:Dano...after you tried everything and nothing seems to work, try a Techlusion R259. Sure...BMW should fix the problem. But after all these years of denial, they won't. So the cost of the device is much cheaper than what you will loose from any trade and the bike will run they way you expected it to run when you bought it without compromising the input devices to your ECU.
Many dealers are installing Techlusion devices and I have no heard of a single device causing damage to the motor. My opinion is its harder on a motor to run it overly lean than it is to run the motor with a more correct fuel/air mixture. Before the 1150 series motors, the European versions of the oilheads were open-loop bikes (no 02-sensor or cats) and ran at 3% CO. So surging was one of those problems us Yanks complained about and BMW ignored. Run the motor at 3% CO and you will experience a completely different motorcycle.
It will do 65 MPH at 4,000 RPM in first? Did not know that.pmdave said:"Well, Officer, I was going 65 in a 25MPH school zone, to keep my BMW from surging."
pmdave
pmdave said:Lessee, Mark, if you put an oilhead in 1st gear, rev it up to 4,000 RPM, and pop the clutch, what speed would that translate to? Or, are you suggesting I should keep it revving at 4,000 and slip the clutch?
pmdave
