S
SDGS Scott
Well, I guess I would call it more of a used BMW re-seller. But the guy istalled a new battery in my 2001 F650 Dakar before I purchased it and did hook up the proper drain line that was supplied by BMW. He instead used the supplied line and just stuck it down the left side of the bike. Yes that's right, he found a hole and now I have acid burns on my starter, water pump clutch cable, engine covers, and even frame and the rear wheel has etching! I am so pissed I want to take the "new" battery and return it to the seller.
So as you understand, I will be replacing the battery with a sealed type. Any recommendations? And hints on how to remove the etching? I did neutralized the acid and did a good cleaning.
Scott
Scott
