Results 1 to 7 of 7
Thread: 2009 R1200GS - side stand support bolt
    Nov 2006
    San Leandro, CA
    Hi All -
    I need/want to replace the side stand support bolt on my GS, it's gotten rather wobbly over the years. However, it would seem the OEM part for mine has been super-ceded by a new part. That new part does not seem to work, does anyone know if I need to replace the internal bushing as well? The wider "collar" on the head of the new bolt seems to hit the bushing before it can engage the threads.
    I have queried a dealer on this and gotten no response.
    Thanks for any help on this.
    Kharon
    Registered User AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    It could be that the bushing is just flared inward by the old, worn bolt. I'd replace everything you can. Bolt, bushing, and the collar bushings if your bike has them.
    Anton Largiader 72724
    Tech articles - YouTube
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    CENTEX USA
    Have replaced mine on 09 and a few same range models. Looked at fiche (Max's) and saw no supersedes, but could be.
    I replace all the parts as Anton suggests as if the pin is worn, the adjacent bushings are most likely as well.
    Nov 2006
    San Leandro, CA
    Here is a pic showing the original bolt I have (circled in red) and the new one. It is the head of the new bolt that seems to be preventing it from engaging the threads.
    It is also not clear from the parts fiche if I need the collar bushings or not.
    Thanks all.
    i should be out riding! wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Quote Originally Posted by khathaway View Post
    Thanks all.
    have a look at the 05-07 model GS side stand parts...it appears to look like your parts...
    https://shop.maxbmw.com/fiche/Diagra...6&rnd=07242017 46 - frame, fairing, cases...side stand
    ~wyman~
    2013 BMW R1200RT - Sassy - Fluid Grey Metallic
    Nov 2006
    San Leandro, CA
    Quote Originally Posted by wyman.winn View Post
    It is, of course, ever so slightly off. I'm gonna order all the new parts and pieces, short of a new side stand, and see how it goes. My side stand has too much play in it at this point.
    Cheers!
    Nov 2006
    San Leandro, CA
    Update on this issue: Got all the new parts and upon doing the install I discovered that if you are going from the 2006-2008 style bolt to the new one, you will not need the slide bushing/bearing as the new style bolt incorporates that into the design. So, now to return that $15 part!
    Side stand has much less play in it with the new parts.
    Cheers!
  1. Replies: 32
    Last Post: 11-09-2015, 02:53 AM
  2. 1994 K75, center stand, side stand lube
    By ted in forum Flying Brick K-bikes
    Last Post: 10-13-2012, 09:59 AM
  3. 07 R1200GS Side Stand Kill Switch
    By Moto316 in forum Hexheads/Camheads
    Last Post: 06-03-2011, 08:29 PM
