Results 1 to 8 of 8
Thread: 2011 R1200RT CB Radio
    dude987
    Any suggestions on best model and install method to hook up a CB radio on 2011 R1200RT? Ideally a CB that connects to a bluetooth headset (does such a thing exist?). Tried doing some searches on this site and google. Saw J&M CB with appropriate attachment brackets for R1200RT. But no bluetooth hookup.
    If you're ready to drop some serious cash, there is a J&M CB Bluetooth Solution. Go to their site http://www.jmcorp.com/ and check out the JMCB-2003E-BW, JBLU-BHDG07-EB03, FGA-345-R12RT, BWCBA-R12RT, HS-EBLU629EDR-UN. In the neighborhood of $2300 if you include a new helmet.
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    The combination of a Sena SR10 hub and Sena SMH 10 headset should do the trick for a fraction of the J&M setup. You will need a handheld CB compatible to the hub.
    I have been using the Sena headset with my 2011 RT with good results since September.
    The Hub is due to be released this fall. In addition to working with many two way radios it will tie in additional resources to your BT system such as GPS, radar detector, cell phone ETC.
    http://www.senabluetooth.com/product..._menu=overview
    2018 R1200RT W - Continent traveler
    2016 S1000XR - Smile Maker
    1976 R90/6 - Just Plain Fun
    TONY2733
    Sena
    Can the Sena be paired with a GPS, Phone and my RT bluetooth radio?
    The Scala Cardo G4 will only pair with one bluetooth external device.
    The book shows many devices but only one can be uased.
    Jun 2009
    Kern Valley CA
    In addition to the headset to headset com, the Sena can be paired to a GPS and phone if it is a monorail signal and a stereo signal (A2DP) from your radio. I use the Navigator IV GPS directly wired to the radio so all works well.
    I wanted to use the GPS as a phone manager but it would compete with the radio connection (both operate as A2DP). Results were not consistent or reliable. I am not a fan of taking calls while riding and prefer stopping to return the call.
    The Sena headset works reliably with the Bluetooth connection to the bike radio system and my cell phone directly connected to the headset. The GPS commands are sent to the radio and are prioritized over the radio media.
    If you have a GPS with single channel Bluetooth like the Zumo 550, it will likely work along with your radio system.
    The StarCom1 Digital lists the following inputs:
    ►Rider headset
    ►Passenger headset
    ►Rider music input
    ►Passenger music input
    ►Rider phone input
    ►Passenger phone input
    ►Remote control
    ►Satellite Navigation
    ►Bike-to-bike radio
    And they list several interface cables for different radios, using PTT or VOX mics.
    Then they have a module to output everything to bluetooth.
    I haven't tried to put together an order, but it looks like you could get the whole shebang for around a grand.
    http://www.starcom1.com/index.htm
    Tulsa
    1981 R100RT - SOLD-
    currently struggling with the RT vs GS question
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    I had 4 Starcom systems mounted. Results were mixed. Seems there were often glitches with cables, and there are sure a bunch of them. I'll sell you all four with headsets for way under a $1000. PM if interested.
    Kevin Huddy
    dude987
    Quote Originally Posted by kltk165 View Post
    Anyone know if the J&M CB will link up with the Navigator IV GPS? I already have a bluetooth helmet that is linked to the Navigator IV. If the J&M CB links to the Navigator IV, I should be good with just the CB unit.
