C
CRUISIN
My '98 R1100RT recently developed a problem with cutting out at lower RPMs. I had noticed a little hiccup occasionally when accelerating from a stop or slowing to make a turn. Yesterday that little hiccup developed into a consistent low RPM miss. At first I was able to overcome it by keeping revs above 3000, then as the day went by, I had to keeep it above 4k. By the time I made it home, I had to drive the last 35 miles in 3rd gear at 5500 to keep the miss out.
Just to help any would-be advisers on diagnosis; I have installed GS tubes, use Auto-lite 3923 plugs (for 3 years), KN filter, set valves about 6k ago and total mileage on bike right now is 68K.
Don't normally abuse a bike by pushing it with problems but was a couple hundred miles from home with no cell phone and alone. Besides it ran perfectly at higher RPM and higher and higher...etc. Just had to keep using a lower gear to stay within the speed limit.
Thanks in advance
klc
Thanks in advance
klc
