T
Travis Bikel
Would like some feedback from anyone who has built and used the $4 carb synchronizer I've read about.
Problem was if they were very far off the atf would suck up into one side and air would get into the atf makeing it useless.
It helps slow things down if you put a restriction , like small hole carb jet, in each tube, or the tiny valves that come with the gauge type syncronizers. It will also eliminate the bouncing of the fluid in the tubes at slow idle.
