Results 1 to 12 of 12
Thread: not charging
    Das Drogenhandler troyboy's Avatar
    Aug 2009
    chillicothe,oh
    not charging
    My Gen lite came on suddenly while riding yesterday. Volt gauge went from 14 to 12. It stayed bright red all the way home. RPM's have no effect on gauge,however turn n brake lites will deflect gauge. I replaced rotor,diode board and brushes last fall. After getting home and letting bike cool down,I started checking around. My rotor still shows 3.5 ohms,rings were a bit dirty from the new brushes so I cleaned them up. I did find a problem although I'm not sure it's charging related.The connections on ATE master cylinder cap. The brown n blue wire broke off with the tab still in the spade. I've searched here and Snowbum"s site and cannot find info on this cap. Would this cause my charging issue ? I see no way of fixing the broken tab,short of getting a new cap. Can this be left unplugged,it's for the fluid level,not the brake lite ?
    Liaison 20774's Avatar
    I'd be looking for a loose wire somewhere if things were working fine up until this situation. And yes, the M/C wire is just for the telltale to indicate you're low on brake fluid...not the actual brake light.
    Aug 2009
    chillicothe,oh
    Only loose wire found was on M/C cap. I cleaned rotor rings and swapped my old diode board back in. Everything seems ok now,lite on at idle,raise throttle lite goes out. Meter shows 13.35 volts @ battery @ 1500 rpms. Had a storm blow in,will test more later.
    Aug 2009
    chillicothe,oh
    Thought I was gettin somewhere. After buttoning everything up,,,I'm back where I started. Gen lite is on and stays on,volt gauge shows 12. Meter shows battery at 13. I've got to be overlooking something. Almost sounds like a bad ground,rotor shows 3.5ohms,brushes good(otherwise lite wouldn't come on at all). She starts right up,just don't charge.
    Einzelkaempfer Whiplash's Avatar
    Mar 2005
    Manistee, MI/Simmern, RLP
    Exclamation
    Did you check the voltage regulator?
    RS Rennsport, Whiplash Motorsport Group
    AHRMA # 59R
    Aug 2009
    chillicothe,oh
    Still searching, I swapped volt reg w/spare,no change. Dash lite works,which means rotor n brushes ok. I currently have main wire harness loose,no nicks,cuts or sharpe bends. I'm thinking,how bout that front relay under the gas tank. From what I've seen,the red wire on right side of diode board runs up out top of motor,then goes to front relay,the same relay has a red wire running to "+" side of battery. Am I correct,that this is the one that's supposed to charge the battery?
    Registered User kentuvman's Avatar
    Jun 2007
    Minneapolis, MN
    If you can't figure this out, I'd call Rick Jones at Motorrad Electrik - a very nice guy who will do his best to help you.
    His web address is http://www.motoelekt.com/
    Rick wrote an Airhead troubleshooting book pertaining to electrical. I bought the CD and copied it to a thumb drive that I keep on my bike in case of a breakdown somewhere.
    From what it sounds like, you may have a bad generator.
    Will be interested to know what the RX is for you.
    Good Luck!
    Aug 2009
    chillicothe,oh
    Found something today. Blue wire in that runs out top of motor to voltage regulator. This couldn't be seen until pulled away from frame.
    Jun 2007
    Minneapolis, MN
    Congratulations! You're on the right track.
    Rick Jones at Mottorad Electrik can provide you with a VR if it turns out you need one. I bought one to beef up the voltage output on my '82 R65LS.
    Let us know what the outcome is.
    Aug 2009
    chillicothe,oh
    I cleaned every connection that I could find. I taped the VR wire and tied the harness back up. My GEN lite is working as it should,on @ idle,goes out around 12-1300 rpms. My meter is showing 13.85 volts @ 2200 rpm's @ battery. Time for a road test to see if anything acts up.
    Aug 2009
    chillicothe,oh
    That's what it was. I'm running same VR,I did swap my spare diode board yesterday-didn't feel like changing it back. But,everything is back to normal.I took a 20 or so mile ride,no surprises volt gauge showing past 13 and Gen lite is acting as it should. I inspected the rest of the harness,hopefully I have no futher issues. This website and Snowbums really hepled out, Thanks to All.
    Jun 2007
    Minneapolis, MN
    Great going! Another Airhead back in action!
