Results 1 to 15 of 29
Thread: Side stand switch
    Kurt Snyder
    Dec 2004
    Vermont
    Side stand switch
    I have a 1995 R1100RSL. I would like to change the side stand switch to the RTP model which allows starting the engine with the side stand down. I remember seeing a parts list a few years ago. I can't locate the list. MAX BMW thinks it requires the switch and a wire harness. Max couldn't find the parts list either. Does anybody know what parts are required?
    Kurt
    Ride safe to ride again
    Aug 2004
    Ann Arbor, MI
    Kurt,
    Try this article. It's from the IBMWR website.
    http://www.ibmwr.org/r-tech/oilheads...nd_start.shtml
    Bob Randolph
    Ann Arbor, MI
    Calgary
    I just wired in a relay myself. Total cost $0, since I had the relay and the wire in my toolbox all ready, but even buying one at the auto parts store has got to be cheaper than the BMW parts. I tied into the neutral light wire to close the relay and bypass the side stand switch. It works like a charm, all saftey features still intact, plus able to run the engine on the side stand.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2019 F850GSA
    Registered User ALIENHITCHHIKER's Avatar
    Oct 2004
    Asheville, NC
    I have come so close to disabling that side stand switch, it really is a PITA. I'm stopped every time though by this visual image of myself riding off with the sidestand down (again). BMW put that thing there for fools like me.
    Steve-O
    Kurt Snyder
    Dec 2004
    Vermont
    Side stand switch
    I hadn't thought about a relay. Great idea. I spent $3.69 on a universal relay and wired it in parallel with the side stand switch. Works like a charm. Runs with the side stand down unless it is put in gear.
    DZIMBRIC
    My 2004 RT will run on the side stand provided the bike is in neutral. This must be something that was addressed by the factory on later models. You may just need to review the RT wiring diagram. If the neutral switch was in parallel with the side stand switch it would allow the bike to run with the sidestand down, provided the bike is in neutral.
    Oct 2004
    Asheville, NC
    Aaah! I'm begining to see.
    So, the conversion still protects from self inflicted injury. Clicking into gear with the sidestand down will cut-off the engine. Hmm. This makes the conversion sound very worthwhile. I'm definitely going to take a look at this. It would be so nice to let the bike warm up for a minute in cold weather without having to put it on the centerstand.
    Steve-O
    Side Stand Switch
    I drove off twice on my 96 with the stand down (previous owner disabled switch) and got lucky both times so I reconnected it back to the factory way. I would like to tie it into being in gear or not, how did you two above wire it so that it works in N but shuts off in gear? Can you draw up a diagram? Thanks.
    ABC,AMA(LIFE),MOA,RA,IBMW MANICMECHANIC's Avatar
    May 2003
    Manitowoc, Wisconsin
    Check out the Internet Riders R1100 tech area. There is a thread with description and pix.
    F.O.G.Rider, Rounder #6,
    Ambassador, WI Airmarshal
    BMWRA Wisconsin Region Rep
    CANADIANGS
    Does anyone know if running an oilhead on a sidestand creates any oil circulation (or lack there of) issues?
    Focused kbasa's Avatar
    Our R1100S and our R1150R will both idle on the sidestand as delivered from the factory. I doubt there are oil circulation issues.
    Dave Swider
    Marin County, CA
    bmwmick
    Quote Originally Posted by Cdn_GS
    It will cause no problem at all, the factory made it standard in 2003 or so.
    Mick
    PS I just finished wiring a relay into my sidestand today. Very easy with a
    Bosch relay. Starts and idles on the sidestand and kills the engine if I
    shift to any gear.
    BUBBAZANETTI
    Quote Originally Posted by KBasa
    i was gonna say, i can't immagine the guy that rode my bike 4,000 miles in 5 years before i bought it started the bike enough to care about such a mod
    neutral engaged - bike runs w/sidestand down
    Any Pictures
    Any pictures of the modifications? I'm interested in removing the switch, but don't want to add another relay (don't want something else that can break) is it as simple as closing the circuit?
    Derek
    Life Member SCJACK's Avatar
    Aug 2005
    Upstate South Carolina
    Yep, just close the circuit.
