Results 1 to 5 of 5
Thread: K1200lt smoking engine
    PRAY BEFORE RIDING roadcrave's Avatar
    Jul 2004
    ninemilefalls,wash
    Hey guys; I read ones artical sometime back on how to get your k1200lt to stop smoking after it sets for awhile parked on its sidestand, Ive experianced that if you tilt your bike to the right prior to starting the engine, it smokes very little. Im used to a cloud of smoke for several minutes which is embarasing...matthew
    Blocking the slow lane
    Edwardsville, IL
    I park on the centerstand all the time, and don't have a problem. You can also tilt the bike to the right side, but with an LT this is a nice invitation to a tipover.
    Jon Diaz
    BMW K75
    MOA Ambassador Emeritus
    Rally Rat boofer's Avatar
    Oct 2004
    Landstad, Wiscowson
    It's an old airhead trick, you shut it off and stay on, lean to right for a bit. This gets more oil to drain down and out of the valvetrain. Centerstand is better.
    Tim
    I always use the centerstand unless the ground/pavement is too uneven.
    josborn
    smoking KLT
    My KLT sits for several days (sometimes weeks) between rides, and always on the center stand. When I start after it sits for 5 days, it smokes for several minutes, even if it was on center stand. Any thoughts?
