Message?
Darryl Cainey
Sir Darby
I tried to post a new topic in Campfire and I got this message.
I tried the back button and still nothing.
I even opened up a new page and tried to start all over again but no luck.
Any ideas? What's a token?
Your submission could not be processed because the token has expired.
Please push the back button and reload the previous window.
Never heard of "token" before...I wonder if that's supposed to be "cookie". When it says reload, you should use the feature at the top of the page to reload or refresh the page. Either click the button or hit F5. If that doesn't help, and it is actually the cookies that are the problem, you might need to go to Tools, Internet Options, and then delete temporary internet files and cookies. You will then have to reenter some information and/or relogon in to various websites that you routinely visit.
Hi Darryl, I did some checking around for you and got this from V-Bulletin...
If this problem is only happening to some people and cannot be reproduced, the probable cause is their browser cache. Have these users either try a different browser or clear their browser cache.
Otherwise an ISP cache may also be to blame.
If your "cookie" file is jammed up it causes some problems also. My suspicion is a small glitch related to the above as you were able to post this question here. HTH, Gary
Tried a different page and I could post a photo in pet pictures?
But not in Campfire?
Well.. I don't know what is next Darryl. I take it it started today? After you cleaned out your cookies file Did you have to log in again? If none of that helps and if you have access to another computer (friend-neighbor?) see if you can log in from there. That would Isolate the forum from your computer. We have had some occurrences lately where some could see a linked photo and some only saw the code. If none of that works and or if it doesn't get better over the next day or so-you might give the office a call. If you want to try a test in campfire when ready-go ahead and one of us will delete it as necessary. Good luck, Gary
If you deleted the cookies, I would say to unplug your modem (DSL) from the wall outlet and leave it unplugged for a while and plug it back in and see if it still continues. This will reset your IP and hopefully you will not have any more occurrances.
I forgot about that one-it's another good one, thanks :thumb
