Results 1 to 9 of 9
Thread: 95 K75s Belly Pan Crack
    SLBAUER
    Question 95 K75s Belly Pan Crack
    K75s fell over enough on left side to crack belly pan in 2 different places. Can these be repaired, if so how? If not, do I need to plan on buying the left side and repainting?
    Standard fiberglass repair techniques with reinforcing on inside plus light bondo and repainting.
    I gave two of those wretched belly pans away. Fashion - bah humbug. I like ease of changing oil.
    SW Ohio
    mine is belly pan-less also, but now the bike is self conscious about it's belly hanging out for everyone to see.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    SLBAUER
    Sound good to me. I have also considered making a cut across the bottom section of the pan where the break is and removing that piece from the remainder of the pan.
    Thanks for the tip.
    SLBAUER
    I have also considered removing the belly pan all together. More motor exposed and less plastic works for me.
    Quote Originally Posted by SBAUER View Post
    Send me the unused belly pans! Especially if they are Marakesh Red!!!!
    Tom Mieczkowski mieczkow's Avatar
    Mar 2006
    St Petersburg, FL
    Belly Pan Gone
    I also have taken off the belly pan on my 87 K75S. I believe one wants to get as much unimpeded airflow over the motor as possible. In Florida where I'm situated it gets pretty hot in the summer. I also thought that mine trapped a lot of crud. I also share Paul's attitude of just let me drain the oil with minimal dis-assembly. And finally I like the look of the bike better without the belly pan. In fact the K75S has more fairing on it than any other bike I have owned. That said I recognize that beauty is in the eye of the beholder. I was really looking for a naked bike when I was in the market for a K75 but the deal on this "S" was too good to pass up.
    And as far as repair, as Lee said, it's a standard fiberglass system and straightforward to fix almost any kind of fracture if you want to retain the pan.
    Tom Mieczkowski
    1987 K75S
    Apr 2007
    Rockport, TX
    Talking Trim that belly fat without Relacor!
    To be accurate, I believe the belly pan and fairing are actually made of BMW's Fibron, which is a composite of fiberglass and ground marble. The stuff is tough and durable---much moreso than regular fiberglass.
    I suppose regular methods should suffice in getting it ship-shape again, though---or you could do what I did (might help if the damage was to the front uppper section which I regard as ugly to begin with):
    ---Jeff
