Results 1 to 9 of 9
Thread: 2003 K1200GT, Kisan brake light modulator question
    Registered User txmxrider's Avatar
    Apr 2005
    Currently wandering in N. GA
    Has anyone here successfully used one of these on this model bike and know which part number they used? I ordered a 20W-DZ for the GT and now I get a "brake failure" indicator on the dash. I suspect I ordered the wrong part number although it might make a difference that the bike also a set of Hyper-Lites (flashing LEDs on either side of the license plate). If others here have used the 20W-DZ then I would conclude that having the Kisan *and* the Hyper-Lite is too much for the bike's lamp-check function to tolerate.
    I'll probably call Kisan this week and see what they say. They'll probably tell me I'm an idiot and ordered the wrong part.
    Thanks for your advice and comments.
    txmxrider
    2003 BMW K1200GT
    2004 BMW R1150RT
    2008 Yamaha WR250R
    Quote Originally Posted by txmxrider View Post
    That's probably what they'll tell you.
    According to their online application chart, the 20W-DZ is for '04 and newer canbus bikes.
    The chart says you should use the 20W-D. That's what's in my bikes. Works great.
    Apr 2005
    Thank you sir! May I have another!?!
    I blame it on the Shiner Bock.
    Okay, so now the plot thickens. I put the original bulb back and still have the slow flashing "brake failure" lamp. Hopefully I didn't dork up something with the ABS or servo system. That'd be about my luck the way things are going this weekend. Maybe there's a reset procedure somewhere. I'll do a search on the forum too but am open to ideas...
    txmxrider
    2003 BMW K1200GT
    2004 BMW R1150RT
    2008 Yamaha WR250R
    Did you take it for a ride around the block?
    The ABS requires some movement (10 mph min. ?) to reset.
    Apr 2005
    No, not yet. Wind, rain and thunderstorms all day today and I didn't want to get her all grungy. This is a little different from the usual 'first start-up' ABS check (the two simultaneous lights that flash in unison until you get a little speed), this is just a single "Brake Failure" lamp. For grins I tried disconnecting the negative battery lead but that didn't help. As soon as the streets dry out a bit I'll take it around the block and see what happens.
    txmxrider
    2003 BMW K1200GT
    2004 BMW R1150RT
    2008 Yamaha WR250R
    Jun 2007
    Minneapolis, MN
    txmxrider:
    See you have a K1200GT - so probably not the same situation as I had with my '87 K75S but here's my experience:
    I went through the same process trying to get the Kisan tailblazer to work - it worked but the red brake failure light stayed lit.
    I put the original bulb back in and ordered this - took care of all my concerns of being seen when I hit the brakes:
    I bought the VectraLight Motorcycle License Plate Frame from Amazon - workes like a charm!
    Here's a link that shows how it works - this, in my op, is the ticket you want
    http://www.amazon.com/VectraLight-Mo.../dp/B000NPMGHC
    Apr 2005
    I put the original bulb back in and took the bike for a short ride. As previously suggested, once the bike moved forward a bit the system self-check cleared the "brake failure" warning lamp.
    Thanks all for the tips/suggestions.
    txmxrider
    2003 BMW K1200GT
    2004 BMW R1150RT
    2008 Yamaha WR250R
    Quote Originally Posted by kentuvman View Post
    txmxrider:
    You, also, had the WRONG model tailblazer. They make the 20W-D specifically for early BMWs with bulb monitoring.
    Put the 20W-D in and all will be well.
