Results 1 to 10 of 10
Thread: battery voltage 2007 R1200RT
    Mick-F norvillnh88's Avatar
    Jan 2009
    Haverhill MA
    What is considered adequate voltage across the battery terminals when the motor is being cranked over? The bike is a 2007 RT, bought new in March 2008, 26K miles on it original battery. I have no problem starting it now.
    Thanks Mick
    Edit/Delete Message
    I don't know if my '05 GS experience holds for the RT, but if it does the voltage will drop a LOT for a short period at startup.
    The following is a plot of startup voltage as sampled using the GS-911 on an OK if not 100% charged battery. The X axis is milliseconds. When the button was hit the voltage dropped to just above 8 volts... probably until the starter actually started turning when the voltage returned to about 11.75v. Once the alternator kicked in the voltage varied between 14 and 14.5 volts.
    Touring Panpsychist Theo's Avatar
    Apr 2010
    Western MA
    Fascinating info, Marc!
    I know very little about the GS-911, just some of the info in the DIYs on its use. Did the GS-911 generate the data and was it captured for you to chart in Excel?
    Thanks,
    Theo
    2009 R1200RT, 2007 Shadow Aero 750 (sold)
    2012 MINI Countryman S, 2004 MINI Cooper S JCW, 2000 BMW 328i
    The GS-911 software that runs on your PC can capture the output of a bunch of sensors save the data in a CSV file. I don't know of the bluetooth phone version can do the same. I used something similar to Excel to read the CSV file and generate the plot. I forget exactly what.
    Just yesterday I used the GS-911 to verify the operation of my clutch switch and discovered that it wasn't operating until the clutch lever was pulled almost all the way to the bar. Link.
    'Forgiven'
    Feb 2011
    SW Montana
    A rested battery that is in good shape should read ~12.5 volts.
    Dana
    God Bless America
    2011RT "Favor"of God
    Canada and the Alps
    Quote Originally Posted by PIPESTONE View Post
    That would be too low.
    Mine sits at 12.9V.
    Braintree, MA
    Quote Originally Posted by GlobalRider View Post
    Mine sits at 12.9V.
    Yuasa says 12.6 to 12.8 V, so they think yours is too high.
    -Tom (KA1TOX)
    Canada and the Alps
    Quote Originally Posted by tommcgee View Post
    For a flooded lead acid battery...maybe.
    I can't control what the rest voltage of my battery is after it has been fully charged. That is the voltage a day, a week and two weeks after my charger has been disconnected. It decreases to 12.8V in the third week.
    True, but what charger is being used has a bearing on what that charger considers to be "fully charged".
    Canada and the Alps
    True, but then it would either overcharge, undercharge or charge a battery just right.
    The rest voltage has nothing to do with the charger other than charging the battery fully or not, in the latter case, it might be a bit lower.
