Unloading my fully packed saddlebags the other day my bike tipped over on it's right side. Felt really stupid and now I know which side to unpack first...
The bike's PO had the sidestand built up so that it wouldn't lean so far down on the left side, so that was also a major contributing factor to the spill. The bike was only a few degrees left of vertcal when I parked on the sidestand; in 20/20 hindsight I should have put it on the centerstand...
The damage was 90% cosmetic that I'll be able to remedy myself over time but the thing that worries me now is the fact that my full tank of gas was leaking a bit during the 20-30 minutes it was on its side*. As far as I could tell the leak was coming from a vent underneath the tank as there was no puncture or damage to the tank itself. The right saddlebag, right brake lever, handlebars and right side fog light took the brunt of the impact.
(*I waited for a neighbor to come over and help me lift the beast upright as I didn't want to strain a muscle like I did the first time this sort of thing happened a while ago.)
In searching for a sticky throttle fix here (now fixed by simple clamping screw adjustment) I ran across a mention of gas leaking into the crankcase via a vent or breather tube of some sort.
Now I am reluctant to start the bike again until I know whether I'm at risk in this scenario. I only started the bike for about 30 seconds shortly after righting it to make sure all was ok and have not started the engine again since.
Perhaps I should play it safe and go ahead and do an oil and filter change before starting the bike again---what say you the experts, please?
