Results 1 to 8 of 8
Thread: 05 R1200GS Headlight fault code
    On the Road
    Sep 2007
    Toronto
    I've replaced the bulb and disconnected the neg. side of the battery for a few minutes but the fault code won't go away. Any suggestions?
    Registered User rebake's Avatar
    green valley,il
    You may have to start the bike to have it reset.Ed
    Ed Baker
    Mar 2008
    Camas Valley Oregon
    Quote Originally Posted by rebake View Post
    Ta Da!!! a Winner! The light doesn't come on until engine start.
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
    On the Road
    Sep 2007
    Toronto
    oh yes I've started the bike many times and done many miles after disconnecting the battery neg side. The lowbeam (replaced) and high beam both work fine but the little light icon on the display continues to show a fault.
    Clovis, NM
    Something isn't right here. I've sucked in 2 low beam bulbs, replaced them and the warning light went out when I started the bike and it went through its checks.
    I'm on an 07 RT but I doubt that makes a difference in this case. I realize this is a question I think we all know the answer ot but have you started the bike and gone to the front to verify the bulb is actually lighting?
    Yes - I read what you wrote above - but have you physically looked at the lit bulb?
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Quote Originally Posted by 129974 View Post
    How's your parking light?
    green valley,il
    +1 check your parking light.Also i had a turn signal bulb loose once that caused the same icon light.Could be that.Ed
    Ed Baker
    On the Road
    Sep 2007
    Toronto
    Thumbs up
    The parking light isn't working .... I had no idea there was a parking light much less how to activate it.
    marchyman you're help is appreciated and I'm kicking myself for not noticing the referance in the Rider's Manual.
    thanks
