AnnapolisAirhead
--Tony
I recently started having issues with my '71 R75/5 when cold. It smokes out the left pipe for a good long while, far beyond getting warm. It only started this since I used the side stand once and most people's comment is that its residual oil from the lean...but it still does after a 4 or 5 mile ride. It's not blue, its white.
I used an infrared thermo to measure the temp on the header just in front of the exhaust nut. The left, one is markedly hotter than the right side while the engine is warming up.
Balanced the carbs with Twinmax after a good warm-up ride and by all accounts, its running and idling very well.
The smoke is white and trails for 10-15 feet before dissipating. After it is really good and hot, the temps on the headers are the same within 5 degrees.
The valves sound good and the bike runs well, but I'm thinking this is the first place I need to look (adjustment and/or valve job).
Of course, the exhaust nuts are frozen (and they are the old /2 leftovers with the dimples), so I'm soaking them thinking I may need to consider a valve job soon.
Hoping to generate a few ideas to look into, even though I think I should know what's causing this--I don't :-(
