Results 1 to 5 of 5
Thread: 2003 K1200GT, yet another final drive quetion
    Registered User txmxrider's Avatar
    Apr 2005
    Currently wandering in N. GA
    I reviewed quite a few threads about the dreaded 9-3 o'clock wiggle but what I am curious about is whether a slight wiggle at the wheel is 100% destined to catastrophic failure and if so, how long does it usually take? Is there anyone out there who has found some play in the FD yet continued to ride for many years and thousands of miles with no failure at all or is it a hand grenade looking for a place explode? If I just discovered the wiggle today should I schedule a repair immediately or have I got some time, maybe even forever?
    Thanks!
    txmxrider
    2003 BMW K1200GT
    2004 BMW R1150RT
    2008 Yamaha WR250R
    Daily Rider jurgen's Avatar
    Red Rocks
    Play in the rear end affects the stability of your bike and should be addressed asap. I would not recommend riding without getting it fixed.
    can you identify where the wiggle comes from? It may be the FD main bearing, or it may be in one of the rear swingarm bearings.
    J?rgen
    Red Rocks
    04 R1150GS adv
    04 K1200RS last of the great bricks
    Apr 2005
    I'm reasonably sure it's the final drive. It has about 1/16" total range of motion when you grab it at 9 and 3.
    txmxrider
    2003 BMW K1200GT
    2004 BMW R1150RT
    2008 Yamaha WR250R
    NC Piedmont Rider ncstephen's Avatar
    Jan 2009
    Hillsborough NC
    Mine developed that at first just a slight bit around 40k last winter. by last summer at about 53k it was a noticable movement. But you could also feel the entire final drive move a little, not just the wheel inside the final drive. Pivot bearings were wearing out. Mechanic said there really isn't any adjustment in them but retightening them sometimes offers some lessening of it,,, sometimes.. Did that and then This past winter at 65K I had new bushings put in which took care of the problem. Now at 73k, all is still nice and tight.
    So your question, perhaps it is a bearing in the final drive, perhaps not. Change the final drive oil and see if there is the typical magnetic whiskers on the drain plug or if there is more substantial metal particles.
    Let us know the outcome
    NCS
    Apr 2005
    Quote Originally Posted by NCStephen View Post
    NCS
    I'm planning to change the oil in the engine and final drive this weekend. I'll let you know. If I see Mr. Glaves at Llano next weekend I'll try to get him to take a look too. Thanks!
    txmxrider
    2003 BMW K1200GT
    2004 BMW R1150RT
    2008 Yamaha WR250R
