I
Note that the burst pressure of the Napa/Wix is rated by Wix at only 60psi - though 35psi to 37psi is the normal range, the pressure relief of the classic K fuel pump trips at 65 Psi so with a correctly functioning pump it should be OK, problem is not all pumps operate correctly. The BMW filter is made to withstand 120+ psi for that very reason.
