rs mirrors
W
wolverine
where is the cheapest place to buy these for my 2005 rt?
Mirrors
Don't know if these are the cheapest, but I got mine here. These are fantastic on
the RT, I love mine and find they are most helpful when you are all packed up for touring. You might check out beemerboneyard.com and see if he has any, they'd be used, but cheaper than these. One piece of advice, make sure you get the washers and nuts that go with these, oddly enough they are sold separately. Good luck. Don
http://ascycles.com/detail.aspx?ID=1792
http://www.ascycles.com/detail.aspx?ID=1792
Here is a source for the mirrors I added to the RT. Great view to the rear and I readjusted the OEM's for a different perspective.
Now have four mirrors looking backwards.
So, you're looking at about $166 plus shipping.
The holes already exist on our handlebars, so install takes about 2 minutes per side.
Good Luck! :german
Greetings
I am not sure about the cheapest, but these work great for interstate riding, with the stock mirror when abjusted correctly you will have a much smaller blind spot.. R1150RT High Mirror - BMW OEM http://ascycles.com/detail.aspx?ID=27347 If you have a tall aftermarket windsheild you may have cut the top corners off the windsheild to avoid contact at lock. I went though a lot of hassle to find mirrors that worked. The part person went and personally fitted those mirrors into a 07rt on the floor before shipping.(what service!:clap) Make sure you order the nuts and washers.
Tony
I bought mine directly from the local BMW motorcycle dealership. If I recall I think I paid about $95.00 a piece for mine, but I wanted to see how they looked and functioned before committing to the purchase.
