Results 1 to 7 of 7
Thread: Things I need to address...
    Barback King rapiddog's Avatar
    Jan 2004
    Acton, SoCal just West of Hell
    Question Things I need to address...
    1981 R100RS
    O.K., bike is up and running, very strong I must say.
    I have a few items I need to address, so I'm up for insights.
    1.) Speedo kicks over and pinned if I go over an indicated 65mph. Odd. Has a new cable.
    2.) Voltmeter jumps around on the + side, and pins itself as well.
    3.) Charging light remains on oh so very dimly even at cruising speed.
    The only time I ever saw this on my '78 /7 was when the rotor was going south.
    The alternator looks pretty aged I'll admit. Not really ready to throw $500 for an upgrade as I'm not sure how long I'll keep the bike.
    I haven't done the upper fairing part of the bike, replacing windshied, and taking a look at wiring, etc.
    I could use some procedure here in where to start...
    "...the burble of my exhaust unwound like a long cord behind me. Soon my speed snapped it, and I heard only the cry of the wind...." Larry of Arubia
    Northern Front Range, CO
    2) Ignore or replace with superior aftermarket. Those voltmeters were notoriously inaccurate. I was told by Master Tech that the "approved" fix involved electrical tape, applied to the face.
    Ride Safe, Ride Lots
    Jan 2004
    Talking
    ...well that's easy enuff...
    Mar 2008
    DeLand Florida
    Actually I find my voltmeter handy. When the turn signals are on it swings back and forth like someone waving their hands. This reminds me to turn off the turn signals when not needed, sort of like this guy.
    Luddite Looney wecm31's Avatar
    Jun 2009
    Eganville, Ontario
    Here is a direct non-OEM replacement.
    Part number is 332103, about $25 online.
    My original one was getting sticky and kinda flaky,
    which according to Snowbum is the end of the line.
    I like having it to keep an eye on personally....
    Gerald P
    The last thing I want to be is just like everyone else...
    1985 R80RT
    1969 Sport Fury Convertible
    Jan 2004
    Quote Originally Posted by wecm31 View Post
    I'm checking these out. So it has the leads and the same light bulb insert in the back? Same depth gauge?
    Jun 2009
    Eganville, Ontario
    Quote Originally Posted by RAPIDDOG View Post
    Not quite.... It was a few months back that I installed the VDO on my bike, the exact details escape me. It does not use the light bulb insert, I did fabricate a connector wire to bring the bulb feed to the light terminal. I had to splice that onto the bulb wire and cut off the original bulb holder. IIRC, it has three (4?) male spade lugs on the back; +12, gnd, light, possibly a ground for the light as well? I seem to recall putting a short jumper to connect light ground to meter ground, cuz' the original bulb holder grounded to the meter case. The mounting bracket was a little different, but all fits perfectly, no issues for depth in my dash.
    A bit of McGyvering, but all in all a good replacement.
    Here's a link to a wiring diagram...
    http://www.egauges.com/pdf/vdo/0-515-012-068.pdf
    Gerald P
    1985 R80RT
