Results 1 to 10 of 10
Thread: Garmin StreetPilot 2730 Repair
    Registered User warthog's Avatar
    Aug 2005
    Charlottesville, VA
    My 2730's digitizer screen has died and I tried contacting Garmin to see if they could repair. The Garmin service department is they no longer repair the 2730's.
    Anyone know of a company repair/replacing the digitizer screens on the 2730's?
    Will digitizer screens from the 26xx or 28xx series work?
    Don Burns
    '02 R 1150 GSA
    "If everything is coming your way, then you're in the wrong lane."- Unknown
    Eastern KY
    I've see the screens on ebay in many ads.
    Registered User tourunigo's Avatar
    Aug 2005
    Larry's River, Nova Scotia, Canada
    I had Garmin (through Raytech in Quebec) not only accept my earlier Garmin 2710 to repair the screen but they replaced the unit with a new 2730. They have a set repair price but if not repairable they apparently will replace the unit with a new one of the closest vintage. Maybe my experience is a one off thing but I do understand that Garmin is very accommodating. - Bob
    Bob Weber
    saltyfogriders@gmail.com
    Larry's River, Nova Scotia, CANADA
    E_Page
    You could probably replace the whole unit for less than it would cost to repair it.
    Aug 2005
    Charlottesville, VA
    Good point I have been watching eBay and Adventure Rider for one. Just wondering if a new/replacement screen would last longer than a used unit.
    Any idea of the life span of the digitizers? Seems like they are the weak point on these units.
    Don Burns
    '02 R 1150 GSA
    Aug 2005
    Charlottesville, VA
    Wonder if a older unit digitizer would fit? One for a 26 series?
    Don Burns
    '02 R 1150 GSA
    Scottish Transplant Picinisco's Avatar
    Mar 2007
    The Desert Southwest, AZ
    Quote Originally Posted by Warthog View Post
    My 2730's digitizer screen has died and I tried contacting Garmin to see if they could repair. The Garmin service department is they no longer repair the 2730's. Anyone know of a company repair/replacing the digitizer screens on the 2730's?
    A used 2730 on ebay will cost you about $150 plus when you register it with Garmin they will give you a one time latest map update.
    2004 R1150GS 1978 R75G/S Frankenbike
    AMA - BMWMOA - BMWRSOC - AZBEEMERS
    Gilbert, Arizona
    Oct 2009
    Torrance CA
    My Nuvi 660 just did the same thing. The touch screen died, and Garmain said too bad. Nice support on a 30 month old product. It turns out the don't fix them anymore because this is a real common problem and they claim they have no parts.
    I found new touch screens from a guy in Hong Kong via eBay for $9 postage paid. We will see if they work in a couple weeks when (if) it shows up.
    Scott
    1988 K75 Low Seat
    2009 R1200R Roadster
    May 2007
    So. Cal.
    Just before x-mas I called Garmin about fixing my 2730 which died about a year prior. The touchscreen no longer worked and could not be recalibrated.
    The woman gladly took my CC number for a replacement. I quickly sent it in, and just after New Years I had a replacement from Garmin. The replacement was a 2820 however. I called Garmin to say hey, whatsup? I sent a 2730 and got a 2820 back. (I'm aware the features are the same). The woman I got this day said they weren't supposed to take the 2730 back (or maybe the computer didn't say that until after they gave me a RMA number) because they were no longer doing exchanges for that model. Rather than renegging (sp?) on our deal, they sent me a 2820 from the warehouse.
    Cost: $186 including tax and whatever. Still cheaper than a new unit!
    __________________
    Nancy
    2013 R12RT, 2012 Yami FZ6R, 07 F650GS (Sold), 09 R12RT (Sold),
    IBA# 529
    Aug 2005
    Charlottesville, VA
    I wound up buying a older StreetPilot (I think it was a 26 series with the storage card and no XM) off ebay for about $35. I opened up both units and the touch screens are almost identical. There were four screws and an 2 ribbon connections and I'm back in business.
    I was originally a little hesitant but figured since Garmin was not going to fix it I would give it a try. I only involved a handful of screws, a small phillips head screw driver, and two ribbon connectors. The water proofing was two rubber gaskets - one where it breaks in half and the other around the touch screen. I have pictures if anyone is interested.
    Don
    Don Burns
    '02 R 1150 GSA
