I removed the cast aluminum top triple clamp, that carries the swivel bearing for the front steering and acts as the attachment point for the front tubes, handlebars, instrument panel,windshield brackets & ignition switch. The bike is a 2003 non abs-R1150R.
Question:
The black rubber "covers" for the top of the fork tubes dried out and fell off.Do they actually have a function beyond asthetics? I cannot see that they seal anything but, as they say, now is the time, but of course I must order them in.
I'll share some insight to this problem that developed as a result of someone having used a bolt that was too short, for retention of that top bracket. The 8x1.25mm bolt must gain enough threads to hold the windshield under vibration from wind & road. It also benefits from using Locktite blue thread locker due to the vibration. The bolt vibrated out while at a place far from home(Chiapas , Mexico) and the threads in the aluminum were damaged as a result of it being loose and me not realizing such.
Question:
