Has to be a monolever airhead -- the oil/hexheads had no-oil paralever swingarms.what year and bike are you talking about? (i see a GS in your profile, but that bike is a Hexhead, not an Airhead. it likely makes a differemce.)
I had originally planned to use a helicoil, but figured that taping for a helicoil would require at least as large a hole as tapping for a 14mm plug. The filler hole is fairly near the edge of the castin and I have some concerns that the casting might crack. I generally don't strip the filler or drain holes and figured that the helicoil's primary advantage would be a stronger thread.
It is an 86 R80 with a monoshock.what year and bike are you talking about? (i see a GS in your profile, but that bike is a Hexhead, not an Airhead. it likely makes a differemce.)
Lostboy is correct. To do the helicoil right, you have to get the pinion gear out of the way. I did mine half-assed and got the helicoil inserted in the half-cocked way that you almost inevitably will when trying to do it in situ. Result? Actually, not that bad. I added a couple washers and some Yamabond and the plug functions as a plug. If observers have poor eyesight, they don't even notice it.I helicoil them. It's a bit of a pain, since to do it right, you have to R&R the pinion shaft. This requires special tools and heat. Since it's such a pain, I usually do fill and drain threads at the same time.
