barron_williams
Monza Blue 1974 R90/6
Solved - R90/6 No Electric Power
I posted a question here
http://forums.bmwmoa.org/showthread.php?t=48468
a couple of days ago asking for some help. Bike suddenly lost electric power. With the ignition switch on, no idiot lights, headlight, turn signals, or starter - nothing.
I appreciate the suggestions I received during the week.
Today I spent some time on it and could use some more advice. Here are updated details.
I traced 13v from the battery into the starter relay (red wire).
13v comes out of the starter relay on the second red wire.
So, starter relay not the cause of the problem?
12.9v comes into the ignition switch (red wires).
12.9v goes out of the ignition switch in the first on position (green wire)
12.9v goes out of the ignition switch in the park lights positions (gray wire)
12.9v goes out of the ignition switch in the headlight position (yellow-white wire).
So, ignition switch not the cause of the problem?
The two 8A fuses on the board behind the headlight are good (removed, checked good, replaced with new ones anyway).
If I remove the fuses, then I have the 12.9v coming from the iginition switch (green and gray) on the right hand side of the fuse holders.
As soon as I put the fuses into the circuit, voltage drops to zero.
What single point of failure for all the electrics is on the downstream side of the fuses?
I'm guessing it is something open/broken because if it was a short, the fuse(s) would have blown or the bike burned up?
But, again, whatever it is is causing total loss of power because nothing on the bike works. What the heck could that be?
Regards,
Barron
Regards,
Barron
