Results 1 to 15 of 25
Thread: pushrod seal replacement
    I just purchase a 1972 R50/5, it is in desperate need of pushrod seals, Is there a serious step by step procedure posted on the web anywhere, as well as a list of replacement components needed? I was looking thru BobBMW web site and they call out a pushrod seal installation tool. Is it needed? My Clymer manual is in the mail to me. Any help would be greatly appreciated,
    thanks
    dan
    Bill Burke
    This article isn't right on point, but you might get some useful tips for reinstallation here:
    http://www.bmwscotter.org/procedures...stallation.htm
    BeemerBoy terham's Avatar
    Feb 2005
    Exit 31, PA TPK
    Try this. It worked for me.
    Pushrod seal replacement.
    Terence
    Current rides R75/5 R100RS R1150RT
    Past rides K100RS R1100S
    My Smugmug
    Liaison 20774's Avatar
    I think the best $25 you can spend would be to buy a real step-by-step manual from Oak Okleshen. He can be reached via email at askoak at aol dot com.
    The /5s have a bit of a nuance when it comes to aligning the rocker arms...not sure if it's covered in the other recommended locations. Oak goes over the issue.
    I see where the pbase link above recommends Oak's manual at the end.
    Hi
    Thanks so much for the replies, I have emailed Oaks for the top end tech manual. Does the manual give the dimensions for the H frame Jig?
    thanks
    dan
    Registered User beemerguru's Avatar
    Foster City, CA
    where do you live? Check to see if there's an Airhead Tech day scheduled soon. This is something typically done in a setting where you learn and see how it's done.
    Greg Hutchinson
    R80G/S (4) 633CSi with 450K mile
    '68 R60/2 '88 K100RS Special Edition
    http://gregsgssite.shutterfly.com/
    I am in Bowling Green, ohio
    Feb 2009
    Chicago, IL
    Unless you want to have a look at your top end and maybe de-carbon heads, pistons, etc.
    There is a way you can "cheat" and save a bunch of time. First you must make sure the side you are working on is on the compression stroke and you can see "OT" in the flywheel inspection window (it's the little black rubber button on the left side). Then...
    1. Remove valve cover.
    2. Remove rocker assemblies (loosen a little at a time in a criss-cross pattern). Keep the assembled and remember what goes where.
    3. Leave the 12 and 6 o'clock nuts in place (the hold the heads to the cylinder).
    4. Pull both the cylinder and head together toward you just enough to get the seals out of the case.
    5. Remove old seals (you will need strong hands or you can also use a strap wrench to give them a little twist).
    6. Replace seals.
    7. Clean and dress mating surfaces with your favorite gasket seal (too many opinions on which one to use).
    8. Push the head and cylinder back in. Replace rockers, torque heads and set vlaves.
    9. Repeat for other side and you're done.
    Seems like a lot of work but it really isn't. FYI, this is the quick and dirty method if you just want to take care of the leak. You don't have to mess with the pistons and this is a big time saver. My guess is most people will tell you "while you're in there..."
    Also, +1 on Oak's manual. The guy is a class-act and the manual is invaluable. He's also very good at answering questions and is widely regarded as an authority on our classic little airheads.
    Enjoy your new ride, Dan!
    Bill Burke
    Quote Originally Posted by dmcbmw356mcn View Post
    Scot Lydiard (see BMWScotter link above) says this about the jig: "BMW made a factory tool for aligning the cylinder head studs in the shape of an H. Don't use it. It doesn't work." His procedure for aligning the rockers without it is described in detail in the link.
    Bill Burke
    Quote Originally Posted by photorider View Post
    8. Push the head and cylinder back in. Replace rockers, torque heads and set vlaves.!
    To this step I would add: begin to torque the two nuts on the lower studs first, to seat the pushrod seals into the block.
    On the Road
    Dec 2005
    Eastern Ontario
    Easy, if you've done it before...
    Pushrod seal replacement is one of those Airhead jobs that are easy to repeat, but not easy if it's the first time you've done it, or if it is the first time for an old Airhead. There are some likely problems that will be present:
    -- removing the exhaust pipes, particularly getting the finned collars off the head without damage
    -- pulling the cylinders back without damaging the gaskets and two stud 0 rings at the base
    --retorquing the cylinder studs with the all - too - common threat of pulling a stud right out of the block.
    Certainly it is a job you can do yourself, but I'd strongly recommend you find an Airhead buddy to walk you through the process -- and don't expect it will be done in one evening. The exhaust collars can stop you cold; right away you will be faced with the choice between patience and dollars.
    Unless there is some imperative to do the job quickly, I'd really be tempted to pull the cylinders and heads completely, decarbonize, clean and lap the valves gently, measure ring gaps, and replace all the gaskets.
    I envy you the job! Good luck(<:
    Registered User ebeeby's Avatar
    McKinney, Texas
    +1 on Oak's top end manual. That and all the experience here will make it a straight-forward satisfying job.
    1973 R75/5
    Registered User skiteach's Avatar
    Woodbury Ct
    Heads can be removed with headers attached. I did top end years ago and exhaust nuts were installed at factory. The wouldn't moved in '78 and probably won't now! They ain't broke yet so I'm not touchin' em!
    '73 R75/5
    Never had a bad day skiing!
    Smile
    thanks again to all, now I am between the rider in me says, take the fast way and the engineer in me says, take it all apart and measure and polish all the casting dimples!
    dan
    Albuquerque, NM
    Quote Originally Posted by Bill Burke View Post
    Continually amazed at how many 'merikun motorcyclists are smarter than factory engineers.
    Kent Christensen
    21482
    '12 R1200RT, '02 R1100S
