The other means to remove the battery is to pull carbs, air tubes, and air cleaner housing (both sides) with filter. The battery will slide right out over the top of the transmission through he opening created by the removal of the air cleaner housing.
then a carb balance is easy and required periodically anyway....
Yesterday 09:02 PM
Not only will the Odyssey never leak acid on your battery tray, it's so much smaller that I manage to fit a <a href=http://www.nelsonrigg.com/store/product.aspx?pid=487 target=_blank>Nelson-Rigg UV2000 XL half cover</a>, in its provided bag, in the space newly vacated behind the Odyssey by the old lead acid battery. This is in my 1989 R100RT. The tool box ordinarily sits on top and does not interfere with the closing of the seat with the Nelson-Rigg in place as shown.
The rubber straps, two needed, are part number 61211243562 from your BMW dealer.
