lazygoodan
Well, I hate to admit this, but I've done a number on my cylinder head.
While looking for the source of the cylinder head gasket leak that I recently posted about, I took off the valve cover about 3 times. The last time, I stripped the threads for one of the the valve cover bolts (lower rear, LH side). No problem, just pop in a helicoil while working on the cylinder head gasket.
I followed the instructions, installed one helicoil, but it wasn't near long enough. The instructions with the kit I bought said to install a second one if the first one wasn't long enough. This seemed to work, but it took a lot of effort to seat the valve cover bolt, and it leaked oil from this bolt when I test rode it.
I let it sit over the weekend, and decided to run a tap down the hole just to clean up the threads. I selected the correct tap (M6 x 1.00) and hand threaded it about halfway down the hole, where it started to bind up. Then I put the handle on it turned it about 1/4 of a turn, and the tap broke off in the hole.
Now what? If it was a bolt, I'd try to drill a hole and use an easy-out. I'm pretty sure this tap was so hard that I won't be able to drill a hole in it. Anyone have experience with this. I sure don't want to pull the head off again it I don't have to.
