cjack
K Bikes Complex by Choice
I've been thru 7 fuel strips on 4 bikes. They mostly broke at the connection at the top where the wires connect to the sensor strip. This is at the top of the filler and is above the level of the gasoline. This connection is encased in some kind of epoxy block. There didn't seem to be any deterioration there, just an open circuit inside the block. I would assume that the connection just internally disconnected due to vibration or improper securing crimp or whatever method was used there. There was absolutely no deterioration of the strip. It's resistance was intact as close as I could get to the place where it was connected to the wires.
My approach to this issue now that the bike is out of normal warranty, is to buy the strips and replace them. I understand BMW no longer advises to do a recalibration. I never thought it worked well anyway. The strips I measured all seemed to be close enough to the nominal resistance. I did not recalibrate the last time this spring...just had my wife with her small hand reach inside the K1200S tank and unplug the old strip and plug in the new strip. Works fine as before. AND, using a BMW part with an invoice for the part as I understand the parts warranty I read a few years ago, I can have a dealer replace it under warranty next time within 2 years including labor no matter who does the labor.
