Results 1 to 9 of 9
Thread: Trying to ID Wheel Hub
    bostonmish
    Spun bearing ...was Trying to ID Wheel Hub
    My /2 conversion rig came with a mix of driveline & suspension parts.
    I'd like to ID the front hub. I thought it was a /6, but now not sure. Maybe /5 ? Anyone know?
    It is all aluminum. It does not have a metal sleve insert around the bearing inner races.
    Michael Stoic
    bostonmish
    Here is the other side
    Eastern KY
    You might try Buchannan's Spoke & Wheel web site as they have info relating to their kits for rebuilding BMW spoke wheels. Should get you in the know...
    Pismo Beach, CA
    Maybe /5 ?
    Well, it certainly is not a /5 hub. /5 hubs are for drum brakes. I'd say /6 or later.
    Like
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Liaison 20774's Avatar
    What kind of rim is that? Certainly doesn't look like the /5 rim shown above or like my /7 rim at home.
    bostonmish
    This is a Buchanan SS Spoke set on an Alloy rim, all wrapped around the BMW hub. It looks very good on the /2 rig. Very meaty.
    So, I guess this IS a Slash 6 hub. Thank you for that ID!
    Registered User bmweuro's Avatar
    Oct 2009
    Northern Cal
    It looks like a 4 rib hub with no large casting in the axle area so that would make it a 75 -80 /6 and /7 hub.
    www.boxermetal.com
    www.facebook.com/boxermetal
    VBMWMO #7770, BMW MOA #48694, ABC #600
    Hi my name is Chris and I am a slash-five-o-holic.
    mymindsok
    If it's a drum hub, look inside the hub and check the casting date. That should give you an idea of when the part hit the assembly line.
    If its a disk hub, just drop by and talk to a good Airhead mechanic. He should know at a glance!
    bostonmish
    Thank you everyone for the help in the ID stage. I wanted to be sure I used the proper procedure to remove the bearing races. That is now accomplished, but I discovered that one side had spun.
    I started a new thread on that:
    http://forums.bmwmoa.org/showthread.php?t=47686
    Michael Stoic
