Hi,
98lee is correct. If it feels softer than a tire, replace it. But be sitting down when the price is quoted! And realize there are 2 fuel pumps - the older one is 52mm in diameter (Bosch) and the newer is 43mm in diameter (Siemens, I think). The rubber dampers are different. Either pump will work in the bike; just make sure you order the correct damper for the pump you have!
Would anyone explain what is gas damper and where is it located? What looks like?
