Results 1 to 7 of 7
Thread: R90/6 Headlight Switch
    CAPITOLATIM
    Hi, my newly acquired 75 R90 has a non working headlight. A get a highbeam on the flash/pass button but that's it, besides the parking light. A BMWMOA send me two used switches , I install on today but getting the same result and no horn.
    The good news is I got the clock and voltmeter hooked up and working...
    So two switches, both bad, is there something on the circuit board I should be chasing?
    Cheers
    Tim in Capitola, CA
    Liaison 20774's Avatar
    What about your headlight relay? Seems to me that when this sort of thing happens, the relay is the problem.
    Registered User skiteach's Avatar
    Woodbury Ct
    Easy enough to test switches with VOM/ continuity tester.
    '73 R75/5
    Never had a bad day skiing!
    CAPITOLATIM
    Switch Tested OK
    I did test the switch with my meter, it was good. How do I test the relay?
    Cheers
    Tim
    Woodbury Ct
    Most likely by replacing. I seem to remember a thread about headlight relays recently.
    '73 R75/5
    CAPITOLATIM
    Relay was stuck?
    I dismounted the headlight relay and removed the hot lead(red) to make sure it was powered, It was when I plugged in back in, viola, the headlights work on both hi and low beams...maybe the relay was stuck. Now Im chasing the horn problem, I tested the horn switch before I installed it and it was working, I notice in the schematics that there a different colored wires for the horn...this is getting to be fun.
    Cheers
    Tim
    Registered User gertiektn's Avatar
    Aug 2009
    Ketchikan, Alaska
    Horn switch is green/black. To the board..
    jim
    I like good stuff. No Chains here!
    1960 R50 -"Hanz"
    1977 R75/7 -"Gertie"
    2004 R1100s -"RFAR1"
