Results 1 to 5 of 5
Thread: Question about '03 F650CS
    Jan 2007
    Payson, AZ
    After today's ride, while backing the bike into the garage, in neutral, I noticed a clicking sound coming from the rear. Never heard it before. So I moved it forward and heard it again, back, heard it again. It was fine when I went out to ride this am.
    Any ideas on what this would be? Belt, maybe? I checked it and seems tight as can be. Anyway, I'm stumped and could use some suggestions as to what might be causing this clicking noise. Thanks!
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    Check for road debris in caught up in rear wheel maybe? :shrug
    Registered User SilverRT's Avatar
    Feb 2007
    Lake Elmo, MN
    Clicking Sound
    You might want to ask this question on the Chain Gange site. My CS does the same thing and always has. I'm not sure it's a serious issue.
    R1200RT '16, R1200GS '13
    R1200RT '07, R1150RT '04 & K75RT '93 Sold
    "It's all about the journey, make the best of the road you find yourself on."
    Jan 2007
    Payson, AZ
    Last time I back it into the garage it didn't make the noise so I'm assuming it was nothing.
    Hey! Am I in the correct thread!!
    Polarbear Polarbear's Avatar
    Clovis,CA
    Some tips:)
    Be sure your belt pulleys(2) are tight and seated well, belts are not too old and worn and wheel bearing noise, which is real bad! No noise is always best. Randy
