Results 1 to 10 of 10
Thread: Would you be afraid to buy this bike?
    Question Would you be afraid to buy this bike?
    Hello, I need some advise on a 1999 R1100RT. The bike has 10k miles and is as new cosmetically. The problem is none of the fluids have ever been changed, except the engine oil and we are not even sure about that. The current owner bought it with 1k on it and does not know if it even had it's first service. It has not been started in over a year and has one half a tank of bad fuel. Naturally the battery is shot and will not even light the neutral light. If he gets it started would you be afraid to buy this bike. Also, how much should it be worth, knowing that it has been neglected and abused in this way? Thank you in advance.
    Registered User ALIENHITCHHIKER's Avatar
    Oct 2004
    Asheville, NC
    This is a sin!!!
    I'd definitely low ball the offer. If you are able to do your own labor, it would be a steal for, say, $2,500. I wouldn't even start it. Bring it home - change all fluids, replace the fuel filter and probably the fuel lines, clean out the tank while you're in there. New tires, new battery, new plugs, valve adjust, retorque the heads. She'll fire right up. Synch the throttle bodies. Ride it hard to break it in. Put 200,000 miles on it.
    Steve
    Current Hottie: '00 R1100RT
    Old Flames: '85 K100RT, '80 Yamaha XS850, '67 Triumph Bonnie, '66 Honda 90 Scrambler
    Northern Front Range, CO
    i'm with Steve- lowball an offer, and DO NOT let the guy start it beforehand- if nothing else you don't want that shellac that used to be gas going thru the system.
    Ride Safe, Ride Lots
    Scottish Transplant Picinisco's Avatar
    Mar 2007
    The Desert Southwest, AZ
    At the right price....jump at it.
    2004 R1150GS 1978 R75G/S Frankenbike
    AMA - BMWMOA - BMWRSOC - AZBEEMERS
    Gilbert, Arizona
    Do not start it untill you have changed all fulids ! Sounds like it could be a good find it you can get the price low enough.
    ________________________________________
    The early bird might get the worm, but the second mouse gets the cheese.
    Brett
    Nov 2005
    Altoona pa
    I agree with the above post. I have a 15 year old VFR in mint condition and things like brake fluid were never changed. When I ask the dealer to do it he said it was not necessary! I told him to do it anyway. My point is that if it had 80,000 miles on all that old fluid then no but most of the other stuff should be ok at such low mileage. I would change the engine oil a few times in the first 3,000 miles and do all the other stuff everyone recommended. I,ve bought quite a few neglected bikes or antiques in the past and with a little TLC they come back to life and love you for the attention. For the past five years I have been riding and wrenching on a 1970 /5 that sat for 22 years and I just do some different things every year now and now she is finally ready to be a daily rider if I wanted her to be. When I change the oil in her it still looks like gold at 2,000 miles but it was not like that at first. Good luck
    Registered User MOTOR31's Avatar
    Aug 2006
    Full timr RV'er, where we park is home. No fixed address or location.
    Another consideration is where the bike has been stored while it's been sitting. Is it in a high humidity or salt humidity area? If so there could be some rust issues inside the engine. WHY was the bike sitting? Was it because it just stopped running or possibly they ran it out of oil or something similar. Did it get dropped into water so the engine got wet inside? It might be a good buy if there is nothing catastrophically wrong with it. Get a scope and look inside the cylinders and see what the top of the pistons look like as well as the condition of the cylinder walls. If the engine can't be rotated fairly easily with the plugs out by putting the bike on the center stand and rotating the rear wheel I'd pass on it.
    DEFINITION OF A VETERAN A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
    Author Unknown
    Oct 2004
    Asheville, NC
    Quote Originally Posted by Motor31 View Post
    Excellent point.
    Was this bike ever licensed in New Orleans (or some other area subject to flooding)?
    Steve
    Mar 2010
    Vancouver, B.C. Canada
    If you buy the bike (I would) along with the fluid changes everyone has recommended I would also run some Techron through it for the first several tanks to help clean out the fuel pump, regulator and injectors.
    +1 on removing the plugs and spinning the rear wheel in 5th gear to make sure the engine is not siezed.
    You may even want to dump the oil _before_ you buy the bike to make sure there is no water in there. (The flooding thing...)
    Even then, if it is dirt cheap I would still buy it!
    It's a brand new old Beemer.
    cheesewhiz
    Quote Originally Posted by 156327 View Post
    Wha chew mean OLD?!?!?!?!?
