Results 1 to 8 of 8
Thread: A bunch of K75 questions......
    Nov 2003
    Dartmouth, Massachusetts
    Are all fuel tanks for all years aluminum?
    Will 3 spoke wheels from 1990 vintage R11XX series bikes fit a K75
    Are there any wire wheels available for the K75. Would any year GS wheels fit?
    What year K75 had available ABS brakes
    In your estimation, what is the best year for the K75
    Thanks in advance
    RoyB....
    2007 BMW K1200R Sport (abs),2007 Suzuki dl650 V Strom (abs),2004 Honda VFR (abs),1972 Honda Trail 90,
    2001 Moto Guzzi V-11 Rosso Mandello
    Registered User beemerguru's Avatar
    Foster City, CA
    Yes
    Yes
    No
    '92 on??
    All run forever. later ABS models had a larger alternator to run the ABS and accessories, early C and T models had drum rear brakes, the rest had rear disk, engines slightly improved over time with pinned rings and changes in compression, front suspension improved around 89 or 90, basic bike never changed in size or weight although there was a change in the gas tank design around '92 where the tank lost half a gallon.
    It all comes down to maintanance and what desireable upgrades the POs installed. You may find a 87 model that's in much better shape even with more miles, than a last year '94 with low miles.
    Stock shocks wear out around 20K miles..the rings on these things don't even seat until then either..but once they do, you can ride 10K miles and the oil level never budges. Engines can last hundreds of K of miles, trannies need a little more attention, always lube your splines - both ends - and keep coming back to this list. Lots to learn and contribute over time.
    Greg Hutchinson
    R80G/S (4) 633CSi with 450K mile
    '68 R60/2 '88 K100RS Special Edition
    http://gregsgssite.shutterfly.com/
    Registered kobukan's Avatar
    Jun 2008
    Saco, ME
    Quote Originally Posted by RoyB View Post
    Can't say for sure . . . haven't tried them all, but 86 was definitely a good year!
    Dean
    '04 R1150RT, '97 1100GS, '99 DR350, '02 DR650, '03 DR650
    Tom Mieczkowski mieczkow's Avatar
    Mar 2006
    St Petersburg, FL
    87?
    My 87 K75S still amazes me. I've thought of upgrading to something with ABS, but I love this bike so much I can't bear the thought of letting it go. An astounding motorcycle that has gotten just about everything in balance.
    Tom Mieczkowski
    1987 K75S
    Registered User kentuvman's Avatar
    Jun 2007
    Minneapolis, MN
    Ditto on Tom's comments.
    My '87 K75S is a keeper and I hope to hand it down to my son someday so he can enjoy it. The bike will outlast me.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    The three spoke wheels are very prone to bending as they are only supported every 120 degrees compared to the "Y spoke" wheels that are supported every 45 degrees.
    Everyone knows that the best K75s are the "Original Litter K75Ss".
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2008
    SW Ohio
    Original Litter K75S's RULE
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by beemerguru View Post
    '92 on??
    1991 was the first year for ABS on the K75.
    Lee
    2016 R1200RS
    MOA # 30878
