subagon
Hopelessly lost
I just bought a 1971 R60/5 with Bing slide carbs (Type 53). It had been sitting awhile and the carbs are gunked up.
I've torn down the carbs as far as I can for their overnight stay in a can of carb cleaner, but can't remove the tickler (which has a plastic cap, well at least it looks like plastic).
All my manuals say to remove a cotter pin, but I don't have one or the hole to put it in. The end of my tickler has been crimped in order to enlarge the end keeping it in place. The crimp looks like the work of the factory, not some ham fisted mechanic.
So how do I remove it?
PS
I found this nice diagram at Bing's website
http://www.bingcarburetor.com/pdf/T53x.pdf
The tickler is #43 and #45 is the cotter pin that mine isn't designed to have/use.
Thanks,
EDIT:
Added 3 pictures of the end of the tickler;
In the last picture you can see the hole the tickler goes through. The crimped end keeps the tickler from passing through this hole and thus my problem.
PS
Thanks,
EDIT:
