Results 1 to 3 of 3
Thread: Trailer Hitch wiring for R1200RT 05
    BMWMIKE
    Dec 2008
    Clarksville, Tn.
    Anyone know where I can find infomation on wiring a plug for a trailer on a 05 R1200 RT ?
    mike
    Registered User Don's Avatar
    Jul 2004
    Townsend,MT
    Bush-tec
    Don Davis
    Townsend, MT
    2007 R1200RT
    + woody
    Aug 2005
    San Antonio, Tx
    Talk to Samuel at Bushtec. They have a module which plugs into the standard wiring plugs on the RT, and isolates the Canbus. They also have a 5 to 4 converter module if you need that (many trailers use a 4 flat wiring, as mine does), and that needs to be plugged in prior to the Canbus isolator to work correctly. It also has the added benefit of leaving you with an extra hot wire for small accessories if so desired. Their system is completely plug and play, installs in minutes.
