KGT Wheel Removal (2009)
Semper_Fi
Honey Badger
The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
Lastly, please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability.
This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
This DIY will cover removing and installing the Front and Rear Wheel Assembly on a 2009 KGT 1300.
Tools
  • T20 for the ABS Sensor Bolt
  • T30 for the Fender Mounting Bolts
  • T45 for the Caliper Bolts
  • 3/8" drive torquewrench
  • Front Axle Socket - I use a Marc Parnes tool*
  • 19mm wrench or socket to use on the Axle Socket tool
  • Front Wheel Stand - I use a PitBull Stand*
* Not affiliated with manufacturer just utilize their products
Process Overview
  • Put the bike on centerstand
  • Remove front fender
  • Remove Calipers
  • Remove ABS Sensor
  • Remove Right Side (Throttle Pinch Bolt)
  • Loosen quick release axle
  • Lift front wheel with front stand
  • Remove axle
  • Remove Wheel Assembly
So let's start - put the bike on the centerstand.
Shop Tip - if you plan to take both tires off, and you plan to use a PitBull lift, you will want to remove the rear tire first.
Using a T30 remove the indicated Fender Bolts (Throttle side)
The pull straight out, the full fender comes off - set aside
Unclip the ABS wire harness from the brake line. 2 locations
To remove the caliper you need to spread the pads a little - this is easily done by twisting the caliper slowly as your are pulling it off.
As you pull back twist to push the pads apart a little.
DO NOT ACTIVATE THE BRAKES AS THIS WILL PUSH THE BRAKE PADS OUT
Caliper removed, now onto the other side
NOTE - I left the caliper hanging because I was only going to be away for one day as the tires where being swapped - if you want feel free to support the caliper if so desired
Using a T45 remove the other 2 Caliper mounting bolts
Using the same twisting technique start removing the clutch side caliper
Calipers are now removed, next is the ABS Sensor
Using a T20 torx remove the ABS Mounting bolt
Once the bolt is removed you can pull out the ABS Sensor
This image shows the sensor fully removed.
It is important to note its position when you are lifting the front end to avoid pinching or damaging the wire/sensor.
Please note that the way the PitBull lift supports the bike it impeeds access to the pinch bolt you need to remove.
So prior to lifting the bike I loosened the pinch bolt and loosened the quick release axle and then lifted the bike.
Getting ready to place the bike lift under the fork legs.
