I have been trying to figure out an intermittent problem on my '83 R100RT. After pulling a moderate grade, the engine starts to run rough almost like it is running on only one cylinder. It takes a couple of minutes to start with the higher load. After about two minutes of decreased load, i.e. reaching the top of the grade, it goes away and all is back to normal. While it running rough, I can still maintain speed, and accelerate though power is down slightly. Vibration is synched with engine speed. Pulling in the clutch causes the frequency to drop and get a bit rougher running at idle.
Same symptoms with wet or dry weather, modest temperatures (60s), and different tanks of fuel. Valve adjustment is right on.
Any thoughts? Ignition module, coils, spark plug wires? I'd rather come up with a strategy than just start replacing components.
Thank you
Thank you
