Are there any resources for someone wanting to disassemble the K-bike final drive to free the pinion shaft for a rebuild? Thinking it would be easier and cheaper to ship the shaft rather than the entire assembly. This is for an '85.
Am I nuts?
Am I nuts?
Gary Wasserman
MOA#38120 DoD#0216 Airheads#12166 BMWRO
'85 K100 (RIP), '08 R1200R (RIP), '82 R100S (was an RT)
The most challenging thing you'll need is a threaded ring tool. This is a BMW special tool. The threaded ring retains the front bearing and thus the pinion. I understand a tool for disassembling some 4-wheel drive hubs will fit, but I have not confirmed this.
It's hard to tell from the assembly diagrams in the aftermarket shop manuals exactly what all the parts are. I'd have to have a bad unit to disassemble to really get a good mental image. In this case the shop manuals basically say, "leave it to your dealer."
I'm sure the original BMW shop manuals have a procedure in them but I've never seen the "official" BMW books.
My guess is I could bring the unit to my local shop and have them disassemble it but by the time I pay them $100/hour it would be cheaper to send the entire unit and let the machine shop do the disassembly and reassembly work.
-Gary
Gary Wasserman
If you are having the splines rebuilt on the input shaft I believe Bruno's wants the whole final drive. That way they can warranty their work easier Vs some one asembling the drive with the incorrect gear lash or bearing preload causing the drive to fail.
Roy
Roy G.
85 K100RT Ol Ruby "Gone but not forgotten"
02 K1200LTC Hoss "Wrecked on 9/21/14"
12 R1200RT
Getting it apart is fairly easy. Big torque on the pinion nut and special wrench for the ring nut or whatever they call it. The problem is putting it back together, shimmed and set up correctly. If you have the tools to take it apart and the special fixtures and tools and an assortment of shims and some machinist's blue to set it up it is one thing but if you don't it will be a problem. For anything other than replacing a seal or O ring - I stay out of there now. It's not worth it to me to be 95% sure I did it right. I want 100%.
Send it to Bruno as a whole unit...he might be able to see some other issue that you might miss when taking it apart.
Its worth the extra $50 in shipping RT.
http://www.brunos.us/
Gary Wasserman
This just occurred to me: I've never seen the spline wear out on an '85! Does yours still have the original coarser spline? If so, you might want to make sure that Bruno's has the spline to match.
