Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 113
Thread: Gas mileage survey
  1. #16
    twowheelsonly
    I get about 45 on highway.. city about 35 to 40 depending on how I accelerate away.. Just installed a 2 Brothers Exhaust so I am hoping to get at least the same.. 2000 RT1100 w 26K
    TwowheelsOnly
  2. #17
    Registered User Greg_K's Avatar
    Mar 2007
    Mechanicsburg, PA
    Quote Originally Posted by Motor31 View Post
    I average low 30's to 35. Highest I have ever gotten is 38. Almost all mixed or city driving.
    Forgot to add I have an 04 1150RT.
    Wow, that isn't very good gas milage. I average 46 - 48MPG riding two-up. Even if most of a tank is short trips (doesn't happen much), I 'll get low 40's.
    '04 R1150RT
    No matter where you go, there you are!
  3. #18
    On the Road
    Mar 2010
    Tallahassee, FL
    About 35. No difference noted between w/s up or down, much difference on cruising speed. <60 produces about 40; >80 drops it to about 30.
  4. #19
    Slow & Easy
    Dec 2005
    Austin, Tx
    38 tp 40 mpg in town. 2004 R1150RT. I seem to run around the 4.3k to 4.7k rpm range in town. If I drop down to the 3.5k to 4k range it will be about the 45 mpg range on the highway.
  5. #20
    On the Road
    Dec 2007
    seal beach, ca.
    So. Cal to Mt. Rushmore, via Glacier NP-2 up & pullin' our piggybacker, 4100 mi.
    ....42.9 mpg!
  6. #21
    Bryan
    Jun 2007
    Bryan, Texas
    Mileage/02 Sensor?
    I have an 04 RT with 98,000 miles on it. For the last three years, mileage about the same as what I just saw posted: 42 to 45, pending load. Added a Uni-go trailer a couple of years ago, gets about 38 if I have a full load.
    Now, the mileage is staying about 36 to 38, without a load. I am suspecting the 02 sensor is due? I can smell some gas when it starts up, smells rich. I am also relating this to a 95R I had previously. It was running rich, low mileage in the upper 30's. Replaced 02 sensor, back to 42 to 47 range, pending load/ride.
    I am about to roll it to 100K, at that time, I'll do some TLC maintenance to it.
    Otherwise, this has been pretty much a trouble free bike.
    Scotchale
    04 RT
    05 CS
    98 Funduro
    10 F 650
  7. #22
    motorcycle cowboy roostershooter's Avatar
    Oct 2005
    East Tennessee
    I get 45 mpg with my '04 RT.
    2013 Goldwing
  8. #23
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    On my 2009 RT I have tracked my mileage for every tank fill and logged the results in a spreadsheet. After just passing 30,000 km on the bike my average mileage has been 4.1 litres per 100km. According to this calculator site: http://www.sciencemadesimple.net/fuel_economy.php that equates to just over 57 mpg (US gallon). This is all my riding from a daily commute on freeway and surface streets to some fairly long trips in the last few years. Frankly I was surprised at the result since I do not ride with mileage in mind and do vary my speed a lot and like to accelerate briskly and rarely use cruise control on long stretches.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
  9. #24
    Just north of Seattle, WA
    My 2002 R1150RTP averages between 34 and 38 mpg on each tank. If I'm only doing the commute, it's closer to 34 mpg. If I'm out on a distance ride, then it's closer to 38 mpg.
    No canister, no CCP, no Techclusion. I have the stock exhaust.
    I get crappy mileage because I'm not aerodynamic with a huge windscreen to push through the air and lights and crash bars hanging out in the slip stream.
    Seattle, WA
    2012 R1200GSA
    2002 R1150RT-P
    1992 K75S sold
  10. #25
    Cool
    This is kinda worthless without speed, elevation, wind, load carrying, and other conditions.
    From this past Friday after work to 1 AM Sunday (basically 1.5 days) I did about 1250 miles going over numerous passes (some up over 5K ft.), rolling hills along the Columbia River, some freeway, mostly 2 lane. Temps were from 40 - 85, I had 1 saddle bag full, trunk full and a lightweight bag on the seat. Aeroflo windshield, stock 99 RT with (now 97K) no C Canister. My typical speed was 75 with bursts up to..., sometimes I had side winds but rarely a headwind.
    Mileage on different fill ups 41.x, 42.x, 45.x, 46.x, 44.x I pushed about 190-220 miles per tank and haven't filled up this last time but that's a pretty representative hwy mileage figure for me.
    City driving can be from 35-42 with the majority in the 38-39 range.
    Hope this helps, back to lurk mode .
    Brian - Everett, WA
    99 R1100RT - Got Kewl-Aid? IBA - SS1K's, BBG
    I started out with nothing and I still have most of it left!
  11. #26
    Thumbs up buzzfeldspar
    I put about 300 miles on yesterday on my '96 R1100RT, mostly on 2 lane roads in SW Minnesota. I got 51.5 mpg. That's higher than normal, I usually get 43-46. I guess it was low winds, and mostly 60-65 mph. and few stops.
  12. #27
    Quote Originally Posted by bdiver View Post
    Where were you riding? We went riding over the Cascades, around the Columbia Plateau, and back this past weekend. We might have passed each other
    Seattle, WA
    2012 R1200GSA
    2002 R1150RT-P
    1992 K75S sold
  13. #28
    Registered User gimmeshelter's Avatar
    Nov 2008
    Detroit
    2005 Rockster here. Never less than 40 mpg, when urban commuting, usually low 40's. Mid 40's touring, non Interstate.
  14. #29
    Tiverton, RI
    04 R-1150-RT, Low of 40 High of 51 and average at 44. I check my mileage quite often so these numbers are current.
    www.OceanStateBMWriders.com
  15. #30
    Jan 2009
    Orange County
    Wow. Great response from everyone. Thank you.
    It looks like the majority of folks are getting 40+ mpg from their rides. A couple of us must have some issue that causes lower fuel economy.
    Thanks for all the comments!
    '87 K75S sold 94578 vin150106
    '80 1980 R65 Bronco brown sold
    '99 R1100rt Opal Blue sold
    '17 1200RTW Alpine White
