Results 1 to 12 of 12
Thread: K75 Mounting plate
    bchurch
    K75 Mounting plate
    I installed a BMW luggage rack on my bike then tried to put the mounting plate in it for the top case. It seems to be impossible?
    Is it necessary to put the mounting plate under the luggage rack when one installs the luggage rack?
    Also should there be a spacer between the luggage rack and the rear cowling? I attached mine right to the cowling.
    Midnight Rider 41077's Avatar
    Jul 2004
    Gresham, Oregon
    No worries.
    The trick is to slide the front edge of the plate under the rack (seat edge vs taillight edge, push it toward the seat, then the rear of the plate (has a notch along the edge) should drop-in and slide back into position.
    There should be foam on the bottom side of the mounting plate that may need to be compressed for this to work.
    Registered User breyfogle's Avatar
    Aug 2004
    Lomita (aka L.A.), SoCal
    Quote Originally Posted by bchurch View Post
    I had to add two standard metal washers (maybe 1/8 inch) at each corner in order to lift the rack enough for the mounting plate to slide under rack.
    '89 K75S Original Owner
    '94 (Beta) R11RS, ( RIP 12-5-2010 courtesy of blind left turning cage driver ) ....
    Apr 2005
    Rapid City South Dakota
    Two Slots
    There are 2 slots in the front of the rack amd 2 slots in the rear of the rack. Slide the adapter plate into the front slots far enough so the plate slips down to the rear slots and then slide the plate rearward into the rear slots. The foam should firm up the plate. Thats the way it works on my Ks
    Harold In Rapid City, SD
    1985 K100RT Bullit
    1985 K100XX/EML Bemel
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    There are 4 rubber washers that are supposed to go between the rack and the body:
    13 RUBBER WASHER 4 46621230798 $2.23
    The are a little thinner that 1/8".
    They help keep your paint from cracking.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Aug 2004
    There are 4 rubber washers that are supposed to go between the rack and the body ...
    I kept the four rubber washers (one at each corner) and added two steel washers at each corner.
    stevenfox8@comcast.net
    OEM and aftermarket luggage/top case racks - K75?
    Does anybody have a photo of the OEM top case rack for K75?
    Also, does anybody know who makes the after-market RACK that's pictured in this listing for a Givi adaptor plate?
    http://www.twistedthrottle.com/trade...tview/206/487/
    Doesn't appear to be the OEM rack.
    (I'm thinking of mounting one of the Givi econo top cases, I think it's the 35 liter model, without the lenses.
    Thanks for any help!
    Steven
    On the Road
    Jun 2009
    Chicago, IL
    Quote Originally Posted by 88940 View Post
    Steven
    Uh, I think Givi makes it
    That page says manufacturer is givi.it. I'll let you know when mine shows up in a few days I bought it to mount the JC whitney topcase, which is kind of silly since that adapter costs more than the topcase, but there you go.
    Registered User robsara's Avatar
    Dec 2009
    West Michigan
    Steven
    That's the Givi E181 case.
    Rob R
    1994 K75 My first bike.
    On the Road
    Jun 2009
    Chicago, IL
    Quote Originally Posted by barooo View Post
    To clarify my comment... I think that whole rack + latch plate is what you get; it replaces the OEM rack and screws into the holes the OEM rack uses. Or at least I hope so... But I've seen 2-3 posts here and on ADV saying it mounts that way and replaces the OEM rack, so it's not just the plate it's the whole thing
    I'll include a pic when mine shows up.
    On the Road
    Jun 2009
    Chicago, IL
    No pic, but the box has the mounting plate and the rack, so you get that whole assembly.
    Chambersburg Pa.
    88940, I PMed you
    I have met the enemy, and he is us
    2011 R 1200 RT
