1024JLC
Looking for your input/suggestions on a final drive rebuild. Tom Cutter of Rubber Chicken Racing Garage (RCRG) appears to get high accolades, but are there other shops/individuals you can recommend.
1st off: It is a 04 R1150RT with 43,000 miles on the clock, and I ride year round including cold wet winters (Northeast region).
Symptoms: A noticeable "rumbling" sensation with bike underway, more noticeable with a lean to the left or to right (more so on the left). Rear wheel is solid if I grab it at the 6 and 12 position. but if I grab it at the 3 and 9 position, it has a shimmy/wiggle. With rear brake applied the wiggle/shimmy is still there, which general knowledge (various websites) indicates it is more than likely the FD, and not the pivot bearing. FD fluid is changed on a regular basis (+/- 10,000 miles), and although slightly dark, no shinny flakes or bits of metal on the magnet, which I assume means that I may have caught it before more expensive/dangerous problems transpired.
FYI - All prices noted below are estimates on my part, so pls feel free to make suggestions regarding gross mis-calculation.
From what I can ascertain, on a cost savings basis, is to remove the final drive myself and send it out for rebuild. Cost should be in the +/- $800.00 range, and since I will have to remove the final drive from the bike then I might as well replace the paralever pivot bearings, approximately $150.00 - $170.00 in parts.
My wrenching skills are about a 5 or 6 on a scale of 1 - 10....but that may be a stretch.
Options
#1) Purchase and replace with new final drive: +/- $1,400, if I do the work myself. +/- $2,000 if BMW does it for me
#2) Purchase and replace with used final drive: +/- $400.00, if I do the work myself. Unknown if BMW does it for me (assuming that they would install a "used" FD for liability reasons), and who knows the condition of the used FD anyway...could be right back here in another few thousand miles.
#3) As described above, sending my drive to RCRG for rebuild, but undetermined amount of down time as he is on vacation until May 1st.
Safety first, but cost consideration a strong second. I just wnet through a messy divorce, and between attorney's, settelment cost and recent refi on the house, funds are very tight, So, please give me your thoughts and/or suggestions......including consideration of an FJR, ST, Connie....etc. (lol)
Jeff
Options
Jeff
